mbc & boost gauge install
Old 16 Apr 2004, 02:04 am
Default mbc & boost gauge install
Where is the best place to tie in you mbc and boost gauge? Power brake vac line for gauge? Black tip line by the tb for mbc?
Old 16 Apr 2004, 10:12 am
The mbc basically replaces the #2 solenoid(goes between waste gate and turbo). Do a search on the mbc hookup. The problem with a mbc is that is spools the turbo up too fast and can cause a flutter and surging. The best way, so far, is to use a dsabc. It only bypasses the PCM control of the waste gate at WOT. Search JasonL I believe he installed this set up! You can also search srtforums.com
I spliced my boost gauge into the brake booster hose. Use a metal tee, I used a NAPA p/n 715-1817.
Old 18 Apr 2004, 01:19 am
wfo57, welcome to the forum!
2002 Inferno Red PT Limited
Mercedes Wiki
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
Boost gauge install pics needed GTCruiser2003 General Turbo Discussions 5 09 Sep 2004 01:40 am
Mopar Boost Gauge install question ksquared11 General Turbo Discussions 1 19 May 2004 02:05 am
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
