Oil Cooler Casting Failure Causing Hate and Discontent
Like Tree5Likes
Old 15 Jun 2014, 10:32 pm
Question Oil Cooler Casting Failure Causing Hate and Discontent
Hello Everyone, My name is Nien and I am new to this forum and to the PT Cruiser owners group. I have an 03 2.4L Turbo and after routine service which I do myself, I noticed about 1/4 cup of oil on my shop floor the next morning. Thinking I may have spun on the new filter with a stuck old oil filter oring on the cooler face. No that wasnt it. I finished the service with a check of coolant and notice coolant had oil in it. Like mud thick. Panicking I pull the oil stick but the oil was clean as when I put it in. I flushed the radiator and engine block. Filled it back to normal and took it for a run around the block. Came back, had lunch and when I came back out. Oil on the floor again. After investigating this is what I found.
The oil cooler that is between the filter and the engine block failed. When the engine is running and the oil PSI increases, oil was being forced through the failed casting and into the coolant running through the cooler (dumbass design). The coolant PSI was never greater than the oil PSI so no coolant seeped into the oil side of the cooler UNTIL I let the car set and the coolant pressure from being baked in the sun rose above the O psi of the non-running engine.
I took the coolant lines off the cooler and spliced them together with a prestone flush T. With new oil and filter I took it for a drive. Came back and pull stick, no coolant in oil, opened radiator cap, no oil in coolant.
Went inside for about 10 min. and came back out and there was oil on my floor dripping out of the coolant line inlet and outlet of the oil cooler.
My question is (yeah I know finally) Can I remove the oil cooler part of the assy and screw the filter directly to the right angle plate? The cooler part unbolts by loosening the filter threads stand off and the cooler fins part is removed.
Can I run my gt with the coolant lines spliced together and the failed oil cooler fins removed?
If I had the $100.00 plus to buy a new oem cooler assy. I wouldnt be asking this, but I have 3 sets of twins and triplets and this is our only ride.
Thanks for any response, hopefully quick ones, so we can get back on the road before grandmas cupboards are all bear.
pappasmurf likes this.
Old 16 Jun 2014, 06:11 am
Default Re: Oil Cooler Casting Failure Causing Hate and Discontent
Capt, welcome to the forum.
I tried doing a search, came up with a lot of good pictures but you know how it all goes together. It DOES look like, if the oil cooler was removed, the oil filter would go directly into the plate BUT, the Turbo PT's are the only ones with the oil cooler. My N/A filter goes directly into the plate and there's no lines going to the engine. Those lines do a specific purpose in keeping parts of the engine and the oil itself cooler (you probably already knew that) as the Turbo engine runs extremely hot. Bypassing the filter, in my opinion, is not a good idea. I'm pretty sure it would run (how long?) but Chrysler wouldn't have added the cooler to the Turbo if it didn't need it.
I'm no expert and would wait further for others with more knowledge on that particular subject to come along with more answers.
Old 16 Jun 2014, 09:54 am
Chrysler seems to like this type of cooler? It is on other Chrysler power plants and in many cases can be by-passed without fluid level temperature increases. Theses factory coolers have been known to fail like you described. However on a Turbo charged engine during boost the fluid temperatures raise quickly and those fluid temperatures need the extra cooling capacity. So you may need to add an addition aftermarket fluid cooler to compensate for by-passing and removal of the OEM cooler?
Old 16 Jun 2014, 04:07 pm
I thought the purpose was to cool the oil?
Old 16 Jun 2014, 04:47 pm
Oil is a fluid, the water goes through them cooling the oil.
Old 16 Jun 2014, 05:57 pm
Question Re: Oil Cooler Casting Failure Causing Hate and Discontent
Thanks everyone for the quick response. Hey Nitro PT are those pictures an aftermarket cooler?? I don't see where the oil inlet and outlet ports. Unless that is an air cooled oil cooler which does not really apply to the dumbass design of the water jacket type oil cooler on the PT Turbos. On my 03 there is a right angle flange (14) coming off the engine block with a oil inlet and outlet for oil. The cooling section (35) which has a coolant in and out port is then attached to that part.
http://www.moparpartsoverstock.com/i...e/i2198771.jpg
I'm no rocket scientist, but does that 2 inches of water jacket with coolant flowing through it really help cool the oil enough to prevent engine failure? It seems that Chryslers reason for the cooler is to compensate for their design flaws in their turbo cooler.
My mistake Nitro PT, that is a coolant jacket type oil cooler in your pics. I jumped the gun due to the coolant and oil ports being inline (position wised)
Old 16 Jun 2014, 06:51 pm
These are commonly used on a few application not just fir PTs or Chrysler model vehicles. BMW has a few models that use a Chrysler engine and they have them as well.
IMO removing them and installing a aftermarket oil or some fluid cooler yields better overall heat control.
The engineering reason for them is to control heat flash caused by Super Charged or Turbo Charged engines during boost levels. They are small but it seems someone along the designing draft board thought they worked? A few of us Data logged fluid temperatures before and after removing them and found no difference.
The one in the picture I posted I keep to show what I tend to recommend removing.
Old 16 Jun 2014, 07:28 pm
Here here, Bravo bravo, Kudos, whatever phrase you want to use I agree with you 100%. Now this is my next question. I've researched a bit (no alot) for an aftermarket oil cooler, but have not seen a water jacket type cooler just air cooled type. If this is the option, where would I mount the cooling core part, behind the engine on the firewall where there is no airflow? on top of the existing cooler in front of the radiator?
I used to be a 450hp Honda B20a in a 88 Accord Hatchback Guy. First to do it and still own the fastest one around.(just cant drive it because I have kids now) But this PT technology is new to me until I can read up and apply more.
Come on all you new generation motorheads what are my options
Old 16 Jun 2014, 07:45 pm
If you look under the car around where that cooler was, you should see an air cooled power steering cooler. Maybe someplace around where that cooler is, you could mount an air cooled oil filter.
Old 16 Jun 2014, 10:35 pm
2004 GT Turbo Oil Cooler
Quite a bit of info and discussion on the factory oil cooler ^^^
You could buy this:
https://darrellcoxracing.com/shop/bo...ig-filter-kit/
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Radiator, inter-cooler, oil cooler, transmission oldorange Tech & Performance Forum 9 09 Sep 2016 07:48 am
What's causing this noise? ptcru1s3r Wheels, Tires, Suspension 4 03 Apr 2012 09:01 am
A/C causing car to jerk.?? clark6 General PT Cruiser Discussions 18 12 Sep 2011 04:05 pm
engine block casting number location luckybadazzboy Tech & Performance Forum 2 19 Sep 2010 05:30 pm
Water Pump - ( Block Casting ) DigitaL101 Tech & Performance Forum 1 22 Apr 2010 09:25 pm
