PT Cruiser Forum Car Videos
Custom Wheels
Dumb question #1
Old 22 Apr 2004, 12:47 am
GT Kruzr GT Kruzr is offline
Default Dumb question #1
Opening statement is that I'm new to this forum, but I have over 18 years dealing with turbo engines. The wife's 12 second Grand National is parked in the same garage with my PT/GT.
With that said: If we use a spring to hold the waste gate closed, does the PCM realise that we are doing this and add more fuel??? OR are we running LEAN and going to burn pistons?
The added air requires additional fuel to keep the balance correct. Does the PCM sense the differential in the sensor in the Cat and add more fuel? There is only SOOOO much fuel the stock injectors can add.[:I] Do we have a problem here ?
Old 22 Apr 2004, 02:21 am
03baggedturbo 03baggedturbo is offline
Send a message via AIM to 03baggedturbo
No dumb questions.. especialy for running lean..
People are doing this mod.. They are talking about it a couple threads down.. under wastgate mod 2003..
ADAM
Old 22 Apr 2004, 05:27 am
divots divots is offline
No the PCM will not add any more fuel to compensate. However, DCX did put a little margin of safety into it's programming so the car tends to run quite rich (about 10:1 afr). Thus you do have a litte headroom to work with. Many (mostly the SRT-4 folks) have safely upped the stock boost up to around 14-15psi & 16-17psi w/Stage 1.
One important thing to note if you're going to do the spring mod is that you need to take the PCM out of the equation as far as boost control is concerned. This means you will need to bypass solenoid #2 and get your pressure source for the wastegate actuator from the turbo housing or the manifold. If not the PCM will eventually "learn" your mod and you will find your boost levels returning to normal. This thinking also applies if you are upgrading to an aftermarket wastegate actuator with a stiffer spring.
I would also recommend that you attach a small turnbuckle to the spring so that you can adjust the tension. Also if you up the boost on the stock PCM you may trigger a P1188 fault code (Part throttle overboost). There are ways around this you can search for here.
Welcome to the Forums!!!
Aloha,
Mark
Old 22 Apr 2004, 12:42 pm
Cal Cruzer Cal Cruzer is offline
Actuall, once your engine is up to temp and it goes closed loop, the input from the O2 sensors will add extra fuel if it senses lean. HOWEVER ( the big however) at WOT the computer does not look at the sensor input, it uses "look up" tables and this is where you could run into problems. But as Mark said, these cars are programmed rich @ WOT which means there is some hidden HP there. Just don't overdo it. Watch your boost guage.
Old 22 Apr 2004, 06:52 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
I think we've pretty much come to the conclusion that spiking 16lbs and holding 15 is a safe zone for our stock injectors...
Just gotta get used to the engine light
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 22 Apr 2004, 11:13 pm
Thank you all for that input..... It's nice to see that we do have some professionals' here that can provide technical input.
While I phrased it as a "dumb" question,,,, I "kinda knew" the answer. I think the turbo PCM ( and the other PCM's) deserves a whole thread for it's own discussion. What can they actually DO, Learn, Forget,,, etc..... How do we trick them ???
More "dumb" questions to follow............[8]
Oppzz, almost forgot,,,,,, Stage One is ordered and on the way. When I get back from Ireland on the 7th of May, I'll be tired but red e to install it.
George C. Thomas
03 GT PT, Inferno Red w/factory flames, AutoStick, Stage 1, Mopar BOV, BTG duals, Airaid, 5 HP fuzzy dice
vB code is On
another dumb question on resetin for my new intake VellianPT Tech & Performance Forum 2 01 Nov 2004 08:29 pm
Sorry for the dumb question crazie.eddie Tech & Performance Forum 3 27 Sep 2004 08:14 am
very dumb question about wipers legion Exterior Accessories Forum 8 07 Apr 2004 04:50 pm
yet another dumb question GTcamster General Turbo Discussions 18 22 Apr 2003 06:47 am
dumb question of the day !! bobs turbo pt General PT Cruiser Discussions 7 21 Feb 2003 08:01 am
  Mortgages | Online Loans | Mortgage Calculator | Loans | Loans
