Codes P0480, P0622 - seems erratic
  #11 (permalink)
Old 26 Aug 2017, 12:03 pm
Default Re: Codes P0480, P0622 - seems erratic
Steve, thanks for responding so quickly. I forgot to check the O2 sensor today, dang it. I checked the relay box, and there were no spares, nor a relay for the fan. (No monkeying with the wiring is evident anywhere on the car). The fan came on in both speeds. The temp gauge is normal, but the warning light didn't come on at ignition on. I saw it yesterday. I pulled the fan connector plug (4 prong) and cleaned both halves, but it didn't need it. I tried the same with the coolant temp. sensor, but you have to be ET to even put a finger on it, let alone pull it off. Looks like you have to pull the Tstat housing ?
Last nite only the CEL was on, now the batt. light joined it. Again there are 14V when running. I can't find anything "wrong".
So glad the emissions test isn't due this week, but may be next month...
2003 GT Turbo AT
111,111 miles +
New alternator not charging, how to check ECM? P0622 imalittleturt Tech & Performance Forum 20 19 May 2018 12:41 pm
P0480 - Cooling Fan Relay but weird... robert99ranger Tech & Performance Forum 6 03 Feb 2014 12:07 am
P0480 need help asap 203turbopt General Turbo Discussions 7 25 Sep 2012 04:49 pm
need some help with another error code P0480 on a 2007 pt cruiser 07ptcruzin Tech & Performance Forum 4 11 Nov 2008 06:27 pm
Computer code # P0480 MINIHEMI46 General Turbo Discussions 10 17 Jul 2007 04:04 pm
