03 pt gt factory tune question
Old 26 Sep 2014, 03:44 pm
Default 03 pt gt factory tune question
I havnt been able to find an answer anywhere yet so figured this would be the best place to ask. Ive been playing with and making parts for neons and srt4s for years now including street tuning and never had an issue with the stock turbo spooling up. Mine is a stage 0 so i know anything over 16lb will give an overboost code so i left it on pcm controlled boost but it takes SO LONG to hit full boost. 4500 rpm average. No boost leaks, turbo is fine and the car was well taken care of with 87k on her. So my question is, does the factory tune not let it hit full boost until 4500rpm? Thanks for the replies
Old 29 Sep 2014, 10:08 pm
2step's Avatar
Default Re: 03 pt gt factory tune question
Are you confirming that with a boost gauge? It should be into full boost well before that. If it indeed checks out, you may have a problem with your wastegate actuator, such as a leaking or ruptured diaphragm, or some amount of negative tension in the arm.
Old 30 Sep 2014, 01:06 pm
No boost gauge yet. It did it with the factory wastegate and now does it on the agp wastegate. Did it on factory bov and the greddy one i have now as well. Im gonna take it off pcm boost this week to see if that fixes the issue. If it does, ill just get an intune a little sooner lol
Old 30 Sep 2014, 04:00 pm
Brian aka 2step, you may want to go read some of the new member Srtgen1 information & posts while there is only a few? That may help you consider a few things for helpful future response to him?
Srtgen1 you should know with your indicated experience that you should have an AFR gauge.
I know with my PT the spiked boost hits so fast it would be difficult to watch the tach, boost gauge and more importantly the road at the same time?
In stock mechanical & PCM configuration 05 GT 14.75+ psi @ aprox. 3400
Old 01 Oct 2014, 12:00 am
This is something i know. Funds tightened up once i got the car so just wanted to throw a few things on while i waited on the the other parts. It just has baffled me since i got it why it takes so long to hit full boost. When it hits, it pulls hard. Just takes forever to get there lol
Factory garage door opener question War_Eagle General PT Cruiser Discussions 5 02 Jan 2012 12:35 pm
Question about the Factory Spoiler/wing WolfmanG Exterior Accessories Forum 22 27 Dec 2010 02:08 am
First Question concerning Tune-up Items PlumCrazyMonkey Tech & Performance Forum 2 18 Jun 2007 11:58 am
tune up question plugs etc. mikey Tech & Performance Forum 7 07 Feb 2006 08:49 am
Question about the factory chrome wheels coolvirus Turbo Wheels/Suspension/Handling 2 30 Mar 2004 01:35 pm
