Lifted throttle noise ?
Old 01 Oct 2014, 06:01 pm
Default Lifted throttle noise ?
2003, 160,000 miles. Second turbo. Today I started getting a fairly loud noise when lifting the throttle after a bit of acceleration 😊.
Sound is a shirt rattle, hiss and flutter, EOT code on the ODB bus didn't find anything when I looked it up, don't think it's related. Any suggestions ?
Old 02 Oct 2014, 09:39 am
UptownSport's Avatar
Default Re: Lifted throttle noise ?
There was a post on dealer PCM reflash that cured some type of turbo noise, posted long time ago
Old 02 Oct 2014, 10:51 am
KA9VQF's Avatar
Might not help at all but you might try making sure all your plumbing is tight.
The air piping on my turbo GT keeps coming loose. No particular reason for it to do so. I'm thinking of replacing all the stainless steel hose clamps.
Don't put off until tomorrow what you might be able to put off indefinitely.
Ignorance can be cured with knowledge, but Stupid is forever.
Old 02 Oct 2014, 11:32 am
2step's Avatar
Do you have a blow off valve or a stock "purge" valve? Your problem could be with either of those if they are not set up just right or if their function has become compromised.
For your homework.....
http://www.gfb.com.au/tech/faqs/19-b...r-pigeon-noise
Old 17 Oct 2014, 11:18 pm
TangerineDream76's Avatar
Originally Posted by johngreen View Post
2003, 160,000 miles. Second turbo. Today I started getting a fairly loud noise when lifting the throttle after a bit of acceleration ��.
Hey there. I am brand new here and this will be my first post. I just bought an '03 Dream Cruiser and I have that same sound. I was quick to find that if I lift the hood and manually blip the throttle cable, it appears that the throttle cable has a "bounce" to it that is the source of the sound. You can even do this with the engine off and get the same sound. I have not yet devised a fix but it seems that MAYBE the throttle cable has like a half inch too much slack in it? Not sure if it is possible to tighten it? Hope this helps you at least with where the issue stems from. If you find a fix please let me know, I have a very busy schedule and have not had time to get back to it after finding the source.
Old 18 Oct 2014, 09:48 am
This is where I'd look.
Loud engine noise and throttle sputter tomcat706 Tech & Performance Forum 3 21 Nov 2013 12:36 pm
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Chirping noise at part throttle littleblueGT Turbo Performance 6 20 Sep 2004 06:20 pm
