AGP Bigturbo (Delta 42)
Old 19 Oct 2014, 09:20 am
Mideskar's Avatar
Default AGP Bigturbo (Delta 42)
Hi.
Have anyone here mounted a big turbokit from AGP?
Is it a direct fit in the PT as in the Neon?
Or is a world of pain and bad languge in the cristalball for my future
// Mattias
Old 19 Oct 2014, 10:02 am
Default Re: AGP Bigturbo (Delta 42)
Without looking back at your older posts, do you already have the the Turbo Lite or GT ???
Old 20 Oct 2014, 01:16 pm
Mideskar's Avatar
I have a -04 GT 5 speed.
Old 20 Oct 2014, 01:25 pm
You might want to look through this older thread...
Best Turbo Upgrade?
Old 22 Oct 2014, 08:35 pm
Smile Re: AGP Bigturbo (Delta 42)
Most AGP BIG turbo kits will fit in the pt just like in any SRT4. Im rebuilding my motor and throwing on an AGP 50 trim kit this winter on my pt!!
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
50 series delta flow muffler jrbsr05pt Tech & Performance Forum 3 22 May 2012 07:51 pm
Do Not Use Delta sonic car Wash Vengence General PT Cruiser Discussions 6 22 May 2009 01:10 am
