General Staged Turbo Problems - or Increased Maintenance
Like Tree5Likes
  • 1 Post By NitroPT
  • 1 Post By Handy_Cruiser
  • 2 Post By CREWZIN
  • 1 Post By soonercruiser
Old 20 Oct 2014, 08:01 pm
soonercruiser's Avatar
Cool General Staged Turbo Problems - or Increased Maintenance
Just a general question for you gear heads...
The Cruiser that I am considering buying has had Stage 1.
And, it's an auto tranny.
Outside of a few less miles per gallon with mileage, what increased long-term costs should be expected to maintain a "staged'turbo", versus stock turbo.
Sorry for my ignorance.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 21 Oct 2014, 04:27 pm
Default Re: General Staged Turbo Problems - or Increased Maintenance
Shouldn't be any difference. Unless you drive it harder. Then you will need to do maintenance at a quicker interval. JMHO.
Old 21 Oct 2014, 05:07 pm
cruserdad1976's Avatar
well for me Id say SPEEDING TICKETS but thats just me--RIGHT?????????
synthetic oil but most of us ues that anyway
Old 21 Oct 2014, 05:15 pm
A STAGE 1 Chrysler/MOPAR PCM will not change any normal maintenance schedule.Nor will having it prematurely wear any part of the engine or transmission.
Your average MPG will still depend of the condition of the engine and it state of tune.
Theoretically you should actually increase your MPG because of the changes that were done to the PCM calibration. Not to mention all or discus them on this thread but one was the timing maps.
It is not ignorance on your part be any means. Very few really know much about the mechanic's of them and logged a comparison data of information between a stock PCM and the STAGE 1.
The TCM changes with the STAGE 1 are even a bigger mystery about calibration changes effecting the transmission shifting capabilities.
JoeX likes this.
Old 21 Oct 2014, 05:31 pm
Handy_Cruiser's Avatar
Yep,
My research indicates the Stage 1 will just give a mild performance boost. I talked this over at length with Nitro and he told me he's found very little horsepower increase. But that's likely at higher RPM's near peak HP. Others report a nice seat-of-the-pants performance increase in the normal driving range. No one seems to know what it does for the transmission. Again, Nitro said he knows what the Stage 1 ECM does to the transmission but not necessarily why it does it. And how that relates to any change in driving experience is up in the air.
My Stage 1 is on the way. And I am excited to try it out. At best I hope to get the mild performance boost. And at worst, it will just increase the value of my PT. Based on what I've found, I expect no bad effects since I drive normally and won't be overtaxing the car. Of course, there will be definitely be a "Handy Stage 1" thread. So stay tuned.
Old 21 Oct 2014, 05:36 pm
Some have even reported BETTER mileage....
Old 21 Oct 2014, 05:44 pm
Yep.
Several folks do report that. Not just the one local self-proclaimed expert.
I figure it is similar to putting a gentle performance cam in a small block Chevy. The improved timing may make the engine slightly more efficient, but at the cost of emissions.
Old 21 Oct 2014, 06:17 pm
Pardon my ignorance frank but if the car your looking at was a Turbo Lite and then the Stage 1 was added, the engine then needs to be run on premium fuel (for optimum performance) whereas the Lite used regular. That would certainly add to the long tern costs of running the car. If however, it was already a full turbo/GT and the Stage 1 added, everything that was already said above comes into play.
Old 21 Oct 2014, 08:15 pm
Talking Re: General Staged Turbo Problems - or Increased Maintenance
Thanks all!
The answers where exactly what I was hoping for, and expected.
As for gas octane, I only use premuim and synthetic oil in my turbos.
And, all the years that I have had turbos, last weekend was the only time that I ever REALLY PUNCHED IT and put a strain on the tranny!
It was at a light where two lanes merge into one after the light, and then merge onto an expressway.
I could see this jerk in a jacked up late model Ford pickup in my rear view mirror, just coasting towards the light change to get a jump on me!
NOT!
The GT vert left him in the dust....and he was trying believe me!
Otherwise, with the turbo I use the pedal sparingly!
Handy_Cruiser likes this.
General Maintenance Tips txh976 Tech & Performance Forum 12 15 Jan 2014 09:57 am
General maintenance. TDragonkirs General PT Cruiser Discussions 3 16 Nov 2013 05:33 am
General Maintenance Question JTsPT General Turbo Discussions 12 10 Nov 2013 01:31 am
06' PT GT How to know if it was staged LittleMissE General Turbo Discussions 17 16 Apr 2012 01:28 pm
Turbo Maintenance PtBrewzer General Turbo Discussions 5 02 Apr 2011 12:46 pm
