Type of intercooler?
Like Tree3Likes
Old 16 Feb 2015, 04:02 pm
Default Type of intercooler?
Hi all, I have an 03 GT with a dented intercooler that might need replacing. Is the IC air-to-air or liquid-to-air? I feel like this should be easy to find out but I haven't had much luck so far.
The guy at the shop told me it could start leaking fluid. Is he right?
Thanks.
Old 16 Feb 2015, 04:03 pm
Default Re: Type of intercooler?
Air-to-Air
The intake is a DRY intake or air only. So the had better not be fluids leaking from the intake system anywhere from the air cleaner to the lower intake manifold.
Old 16 Feb 2015, 04:06 pm
btw WELCOME TO THE FORUM
Old 16 Feb 2015, 05:15 pm
Thanks.
Only if you consider air a fluid....OR - the dent was deep enough to hit the radiator above/behind the intercooler...
Welcome.
Old 16 Feb 2015, 05:50 pm
Welcome.
You would have to destroy the intercooler get to the radiator.
Old 16 Feb 2015, 06:11 pm
Handy_Cruiser's Avatar
Thanks.
Welcome to the forum from the great sovereign state of Arkansas!
Arkansas is normally the beautiful sultry home of barefoot young uneducated women in tube tops searching for men with study jobs. But right now, it's more like the frozen wasteland of one of those forsaken northern states.
As already said, the intercooler on a PT Cruiser is air cooled. There is no liquid coolant to leak out. It's a likely honest mistake by your mechanic but it does confirm that he does not know a lot about turbocharged PT Cruisers.
Luckily, salvage intercoolers seem pretty easy to come by. I know where one is laying on the ground right now. You can likely pick one up at a salvage yard or on eBay fairly cheaply. I believe the GT and the turbo lite use the same one. I suspect all are the same for all models but another member will need to confirm that. You can likely replace it yourself if you are moderately handy with a wrench.
Here's a photo of mine with the bumper cover removed. It's the part below the bumper. The Diet Coke is optional:
Old 16 Feb 2015, 07:18 pm
All the turbo components are the same.
Handy_Cruiser likes this.
Old 16 Feb 2015, 08:34 pm
Actually if his mechanic did say that about fluid and asked if it were water to air this would mean he is at least a modder in performance
I have had many heated debates which are better on a few forums.
Old 16 Feb 2015, 08:56 pm
Or the mechanic might just have experience with big trucks and/or industrial diesel engines. Many of these have liquid-cooled intercoolers. I think Cummins first used them in about 1970. It was actually incorporated into the intake manifold. It allowed for a very compact design. They used a liquid-cooled oil cooler on the same engines.
Cummins must of liked their liquid-cooled intercooler so much, they put their logo on it:
Of course, Mack had to be different. Here's there air-cooled intercooler. I believe they started using these on their 300 Maxidyne engine in the early 1970's:
Old 17 Feb 2015, 09:19 pm
Wow thanks for all the info guys! I think Handy is right and it was just an honest mistake.
I've come across these forums a lot over the past few years, since I got a PT. Good to finally join.
Lug Type ? red98gt Wheels, Tires, Suspension 6 30 Jul 2014 07:14 pm
Oil Type o8bluept General PT Cruiser Discussions 7 20 Mar 2010 12:22 pm
What type turbo? 07GTDriver General Turbo Discussions 5 15 Nov 2007 09:30 am
Type of gas cfra7 General PT Cruiser Discussions 10 19 Jun 2007 12:24 pm
Oil Type Revisited yobiebs General Turbo Discussions 5 02 Jul 2003 12:27 am
