rebuilt turbo now it doesnt spin
Old 24 Feb 2015, 06:08 pm
Default rebuilt turbo now it doesnt spin
Ok I followed Busted pt's turbo rebuild step by step. the turbo spun freely when before I put it in the outer houosing..(i had to tap it with a hammer to get it to seat good to get that big a$$ snap ring to seat. I didnt tap the shaft just the backing part where it seats in. I didnt check to see if it still spun once it was mounted to the turbofold like a dumbass. Then I put it all back together and it wont spin unless I use my finger with some force. I assume I have to pull it and start over again I assume. Im realigned everything like it was before the teardown.
2003 pt cruiser turbo 5 spd, its a basket case
Old 24 Feb 2015, 06:16 pm
Default Re: rebuilt turbo now it doesnt spin
Did you put the spacer back in between the turbofold and the turbo unit?Can you get a pic from the air cleaner side of the unit to see if the impeller is up against the side of the housing.
Old 24 Feb 2015, 06:30 pm
yep the spacer is there and theres no shaft play. im guessing i just overtightened the impeller bolts. should that center section be that tight in the outer side?im so freaking irritated im tempted to buy another used turbo just so i can drive the car and rebuild one later to resell it and recoup my money
Old 24 Feb 2015, 06:38 pm
yep the spacer is there and theres no shaft play. im guessing i just overtightened the impeller bolts. should that housing be that tight in the intake side of the housing or whatever its called.
You said it turned freely before you put it in the housing. There is a line up pin in there also. That's lined up with the cartridge and the aluminium housing? Not sure if you could actually could get the snap ring in if you didn't anyway. The only resistance should be the lube. I have to go out for a bit Will check on you later.
Old 24 Feb 2015, 06:43 pm
i made sure it was all lined up. im going to pull it back out now so give me an hr or so
Old 24 Feb 2015, 06:51 pm
Post some pics if you get a chance. Good luck.
Old 24 Feb 2015, 06:55 pm
A rebuilt Turbo charger assembled in the housing should perform like the videos.
Core without housing.
Complete Turbo installed in housing.
Old 24 Feb 2015, 06:59 pm
Originally Posted by NitroPT View Post
A hoe rebuilt Turbo charger assembled in the housing should perform like the videos.
That hoe be loose Nitro.
Old 24 Feb 2015, 07:01 pm
I did edit it you were just to quick to respond...
Old 24 Feb 2015, 07:17 pm
i skipped that step about checking to see if it spins. i was so excited to finally have it rebuilt and have no shaft play that i forgot to check that. the intake is off and i just have to unhook oil feed and coolant feed and the turbo is free.be back in a few
Rebuilt PCM for 2004 Turbo mycar Tech & Performance Forum 13 17 Sep 2014 10:35 am
who says na ptz cant spin? brightlight07 Tech & Performance Forum 26 24 Oct 2008 10:29 am
To spin or not to Spin? PT Lilly General PT Cruiser Discussions 26 14 Jun 2005 05:35 pm
Test Spin Mel K Turbo Performance 6 17 Jan 2004 05:35 pm
