Diablosport help
  • 1 Post By NitroPT
Old 12 Mar 2015, 04:19 pm
Default Diablosport help
He guys, I bought a used unlocked Diablosport Tuner. I plugged it in, downloaded the tune and took it for a drive. I began to spit and shudder under full boost, so I removed the tune and regapped my plugs. Now when I plug the Tuner in all my warning lights come on (airbag, low fuel, abs, ex) and the words "no bus" come in the message center. Its an 04 Gt high output, any ideas?
Old 12 Mar 2015, 05:50 pm
Default Re: Diablosport help
Well hopefully you did a PCM back up before to uploaded or made any changes.
Re-upload your base/stock file. Use a SCANNING TOOL only NOT the key dance, access the OBDII Diagnostic port and note the DTC's and then clear them.
After that start your PT.
Read through this thread.
http://www.ptcruiserlinks.com/forum/...iser-parts.htm
Then start over again as if you just got the DiabloSpoprt (? which model DSP,DST,DSI). MAKE SURE THAT YOU HAVE A FULLY CHARGED BATTERY OR CONNECT IT TO A CHARGER WHILE YOU DO THE BASELINE SET UP. Do a back up of you stock PCM. Then start the PT and make sure that part is ok. At this point you can now attempt to upload the tunes or make changes to calibrations in the PCM.
I RECOMMEND TO USE ONLY THE 91 TUNE.
Old 12 Mar 2015, 08:52 pm
Its a dsp. Yeah I put my stock tune on the Predator, then put the Diablo tune on. After driving it (and misfiring like crazy) I put the stock tune back on with no issues. Now that I regapped my plugs and try to hook the dsp up I get the "no bus" error. I talked to 2 Dodge/Chrysler techs about the problem. My buddies dad is a Dodge tech with 20+ years of experience and he says I fried my Pcm. I dont see how that's possible because I daily drive the car without and issues or CEL. The other guy I talked to is a Chrysler tech and he said "no bus" means no communication between the Pcm and gauge cluster, however if the gauge cluster is working fine until I plug into the Obd2 port and the port my be my issue. I have to plug in my generic scan tool to see if it will communicate. If it doesn't I have to check the gound wires going from the port to the Pcm and to the gauge cluster. Also check the "can bus" wire at the Obd2 port to the Pcm. I just wanted to see if anyone else had these issues before I have to rip my dash apart and trace wires.
Old 12 Mar 2015, 09:34 pm
Old 12 Mar 2015, 11:43 pm
Usually when I get the no bus error either the battery is bad or the battery cells need refilling to the proper levels. Some will say "Hey its a maintenance free battery", my battery is a maintenance free battery and I am still filling it up every two months to the proper fluid levels. As NitroPT says make sure its a fully charged battery.
Old 12 Mar 2015, 11:54 pm
Look carefully at the Dignostic port connector pins for any damage, like bent pins.
Your problem may have been pre-existing before the DSP calabration?
Your Predetor is no longer supported by DiabloSport. My advise would be to un-marry it and sell it . Then purchase a DST or DSI which is still supported with free online updates and information.
Not sure what the gapping has to do with your problem? I run a DST and gap .028 for N20 and for normal Dailey driving .042. My customers PTs I set always to .042 useing Champion Copper top single electrode spark plugs.
SPLNeon likes this.
DIABLOSPORT INTUNE TommyBlazin Classifieds: For Sale/Trade 6 07 Jun 2015 06:35 pm
Looking for Diablosport Predator FastNLoose Classifieds: Want To Buy 5 04 Oct 2012 09:23 pm
FS: Diablosport Predator w/usb 03GTCruiser Classifieds: For Sale/Trade 5 22 Aug 2012 03:57 pm
Diablosport trinity for 06 gt? Jakester23 Turbo Performance 4 06 Apr 2012 06:42 am
Diablosport is looking... loxmith General Turbo Discussions 0 24 Oct 2008 07:00 am
