SRT4 WGA on an S1 HO PT...
  • 1 Post By NitroPT
Old 06 Apr 2015, 06:20 pm
VanillaVert's Avatar
Default SRT4 WGA on an S1 HO PT...
Ok, so through the magic of CL I am apparently going to get my hands on an S2 wastegate off an SRT4. Well, the guy says it's never been installed but that's what it was bought for.
So, any ideas if it's even worth it or should I go ahead and replace? More headache than its worth? I have no problems at 12-13lbs boost now but always looking for that next small leap in power!
05 PT GT Vert, Airbox mod, K&N filter, NeedsWings intake pipe, Mopar BOV, MSD wires, Autotecnica Chrome Spears, APC Taillights, Mopar Stage One, UltraGauge, Energy front suspension kit, Moog spherical bushings
Old 07 Apr 2015, 08:19 am
Default Re: SRT4 WGA on an S1 HO PT...
Your limitation with stock parts is 18psi and then you must change other parts and calibrate the PCM. For the most part 12-13psi is not bad 15psi would be the goal without having to worry. 15-18 the PCM will fight you if you stay in the throttle without calibration adjustments. If you plane on running more than what you already are you should invest in a wide band to watch your AFRs. (air fuel ratio). Just my opinion for safe reliable power increase and what I would tell my customers.
SPLNeon likes this.
Old 07 Apr 2015, 11:07 am
Can I dial back the arm on an S2 wastegate to keep me around 15-18lbs? Like maybe with a manual boost controller?
Still looking for a wideband... that and a 3" downpipe too.
Old 20 Apr 2015, 08:02 am
vipergts's Avatar
Sell it, use the money for a nice dinner instead of wasting your time...
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
gt vs srt4 Melition Turbo Performance 92 03 May 2014 10:47 am
Srt4 pcm 99PlyNeon General Turbo Discussions 3 15 Aug 2011 03:56 am
03 pt gt vs srt4 TD04PTGT PT Cruiser Videos 0 02 Apr 2009 12:20 am
SRT4 for a day (or so) don668 Turbo Performance 4 09 Sep 2004 06:49 pm
PT GT VS SRT4 macster General Turbo Discussions 25 22 Dec 2003 10:00 am
