Exsaust help!!!
Old 01 Jul 2015, 11:53 am
Exclamation Exsaust help!!!
I have a 03 dream cruiser and I curentlly have the borla cat back k&n box Mod mopar bov and diablosport trinity I wanted louder exsaust ans more power
Would the needs wings 3in downpipe 3 inch o2 housing and dump pipe be a good combo also getting the electronic butterfly valve for the downpipe
Old 01 Jul 2015, 12:41 pm
Default Re: Exsaust help!!!
*If you have the DST then do some calibrating. You can also contact Keven at Skyed Syked Ecu Tuning - Dodge Neon/SRT 4 - Hemi Ecu Tuning and he can raise your torque limiters and give you a little(1-3psi) more PCM controlled boost so you can get a solid and effective 15-18 psi without having to change to much.
*If you want louder then look into electric cut out and the other 2 items you mentioned.
Last edited by NitroPT; 01 Jul 2015 at 12:43 pm. Reason: *been there done that experienced!
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
