2004 pt cruiser turbo touring problem
Old 27 Aug 2015, 06:54 am
Les Les is offline
Default 2004 pt cruiser turbo touring problem
My son inherited a 2004 pt cruiser 2.4 liter turbo from my father in law. It runs great at low rpms but starts to sputter and buck at 2200 rpms can anyone point me in a repair direction thanks
Old 27 Aug 2015, 07:18 am
MJKnight's Avatar
Default Re: 2004 pt cruiser turbo touring problem
You need to do a key dance to pull the codes
this will give you an area to check
1. Cycle the ignition key On - Off - On - Off - On- within 5 seconds.
(KEY POSITION TO ON NOT TURNING CAR OVER)
2. The odometer will show the P-code for the corresponding Diagnostic Trouble Code number.
Old 27 Aug 2015, 07:59 am
This will help if you have the engine lite on.
Old 27 Aug 2015, 08:30 am
If your engine light is on I don't recommend you do the key dance. I recommend you get an OBDII Scan Tool to reset the diagnostic trouble codes. I got mine at Harbor Freight.
Search results for: 'OBDII scan tool'
Old 27 Aug 2015, 08:31 am
LionPT's Avatar
Most likely it's the camshaft sensor, but you should pull the code to make sure.
Old 27 Aug 2015, 08:50 am
New ignition wires and spark plugs (Gapped at 0.040) certainly couldn't hurt....
Old 27 Aug 2015, 02:36 pm
Key dance will be better than nothing. You can hurt anything by trying. But you don't always get everything. That way. If you show nothing the you might get it read at the auto parts store.
Old 27 Aug 2015, 04:35 pm
rockandroller's Avatar
I agree that totally sounds like camshaft sensor - key dance it! (If check engine light is not showing, its possible your C.E.L. might be burnt out...)
Also a quick check might be to disconnect the battery for ten seconds ( If it's an intermittent camshaft sensor fault like mine was, the problem will disappear for a day or two... )
2004 'Turbo Lite'
big problem 2005 touring, non-turbo jishieldsjr General PT Cruiser Discussions 9 05 Aug 2014 11:06 am
2004 Turbo Touring Maintenance Questions firemedic1560 Turbo Wheels/Suspension/Handling 9 05 Mar 2012 12:09 pm
2004 pt cruiser turbo touring srl123 General Turbo Discussions 15 17 Feb 2012 11:01 am
2004 PT Touring Turbo parts FS InfernoPT Classifieds: For Sale/Trade 3 06 Oct 2009 08:09 am
2004 turbo edition pt cruiser problem tbocruiser Tech & Performance Forum 1 06 Mar 2009 02:41 am
