03 Turbo clutch bleeding
  • 1 Post By myckee
Old 16 Jan 2016, 05:01 pm
Default 03 Turbo clutch bleeding
What is the right way to bleed the clutch on a 03 turbo PT?
It ain't the size of the dog in the fight, it is the size of the fight in the dog
71 Dodge Dart 340 4 speed
71 Plymouth Duster Pro-Street
71 Plymouth Duster 340 4 speed
85 D350 2wd 440 cid
86 Dodge Omni GLH Turbo
93 Dodge Dakota 4x4
01 PT Base Model
03 Dodge Durango 4x4
03 Dream Cruiser "Money Pit"
Old 18 Jan 2016, 03:25 pm
Default Re: 03 Turbo clutch bleeding
You should be able to read the exact procedure in the service manual, but briefly, the clutch on the turbo PT's is reverse from how you would bleed your cars brakes. For your brakes, you would fill the master cylinder and bleed from the nipples on the calipers.
On the Turbo clutch, you actually need to push the fluid up into the system from the nipple and up into the reservoir.
Old 19 Jan 2016, 06:42 am
What kind of tool/pump is good for reverse filling in these cars?
85 D350 2wd 440 cid
93 Dodge Dakota 4x4
01 PT Base Model
Old 19 Jan 2016, 08:06 am
google "hand operated bleed apparatus". i could probably make one out of a gatorade bottle, some tubing, and an air compressor with a blow gun.. but there is an alternate method that requires a helper instead of a tool. see picture 4.
______________________________________
personally i'd try loosening the nut marked 3, pulling the pedal up, and tightening it (lengthening the shaft). if you need to bleed the clutch and it isn't because you took it apart, you're likely pissing in the wind trying to bleed it.
Old 19 Jan 2016, 10:24 am
At Walmart I bought a MityVac pump/vacuum device. It was about $20 at the time. I think they still sell them, but you would have to check, or buy one on ebay or an autoparts store.
With that handhelp pump, pushing the fluid into the system is pretty easy. You can also use it for other vacuuming/pumping needs like bleeding the brakes etc.
Probedude likes this.
2004 2.4L Turbo-Clutch problem TBraswell75 General Turbo Discussions 3 25 May 2014 09:00 am
Clutch Bleeding starchief1 Tech & Performance Forum 0 08 Jun 2011 12:06 pm
WTB: Non Turbo clutch Justinm84 Classifieds: Want To Buy 0 26 May 2009 04:47 am
clutch master cylinder bleeding directions? termanpt83 Tech & Performance Forum 1 01 Feb 2009 08:00 pm
Bleeding the clutch opelenvy Tech & Performance Forum 1 15 Oct 2008 02:27 pm
