found my boost leak! its on the oil return line of the turbo. is this normal?
Old 04 May 2016, 05:25 pm
Default found my boost leak! its on the oil return line of the turbo. is this normal?
hello everyone. I have had a big boost leak that I've been trying to find and couldn't find for almost a month now. i have a boost leak tester and used the soapy water method. it would only hold up to 15 psi under the boost leak test and then fall to zero within 10 -15 seconds and i could hear a loud hissing noise which was near the turbo. i finally located the leak and its coming from the oil return line where it mounts to the turbo. a bunch of air is leaking out of there. does anyone know what this could mean? is there supposed to be boost pressure in there? my car has a diablo tune and only hits 9-10 psi of boost and holds 5 psi to redline.
Old 05 May 2016, 02:04 pm
Default Re: found my boost leak! its on the oil return line of the turbo. is this normal?
I would say no it shouldn't. Sounds like you need to rebuild it. Maybe some others have some insight on this.
Old 21 Jun 2016, 02:00 pm
Chris_TurbosUnleashed's Avatar
Just so I understand what you are doing, confirm that you are capping the air inlet side of your compressor cover and applying a boost charge between the compressor outlet and throttle body? You have determined there is an air leak at the oil return flange?
When you reply please email me at chris@turbosunleashed.com because I am not on this forum regularly.
Thanks!
Chris-TU
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Return line leak, needs to be replaced Shoky76 General Turbo Discussions 3 30 Apr 2016 12:28 pm
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
Oil feed line leak to turbo PTCruisinTurbo General Turbo Discussions 1 30 Dec 2013 01:31 pm
How to access bolts of turbo oil return line MarcoB General Turbo Discussions 16 17 Dec 2013 02:15 pm
Impending turbo doom, or just a clogged oil return line causing whine and smoke? icezebra Turbo Performance 5 05 Oct 2008 04:14 am
