I'm good. Got the new one in hand. Kinda pissed the new one is made out of the same material as the last one. Sure wish I knew the part number of the original. Pretty sure the turbo end was made out of the same material as the breather box end on the original. This new material just gets very brittle on the heat of the turbo. Probably over torqued the clamp as well. Guess I'll add looking at this to list when I do the oil changes in the future.
Un fricken believable!!!!!!!!!!!!!!!!!!!!!!!!
![]() Well it is just another member I need PM help off the forum! ![]() |
Thank you for the e-mail Stephen aka Guito> I had forgotten that I replaced yours as well.
![]() While auto wreckers are a good source for parts and you-pull-it or Pick-n-pull or those type where you get your own parts you can learn how to remove them it is generally not a place to gather empirical data for conclusion of what parts wear. There are just is to many absent variables to assume anything for any standard. The PT Cruisers that I work on are different years and different stages of wear condition for the overall vehicle. These are not all California or garage kept PT Cruisers either. I just called a friend at *A&R Autotech ask Ron the owner/operator how many he has replaced on PT Cruisers. He said that he can recall about 3 in the last year and that it is something he always looks at when PT Cruisers come into his some. He get about 1-4 PT Cruisers in for some kind of work every month. Currently there are 2 PT Cruises in his shop. A& R Auto Tech 916-645-1883 |
I have seen many occasions were people have had this issue. On three different groups. So it is more common than some believe. Milage doesn't seem to be a factor. I had been suggested how much you boost time play a role. More heat then. Sounds logical.
Mine never had a chance to get old and brittle. I replaced mine early on with some silicon elbows, hard tubing and rubber grommet(s) for the small hoses fittings. I did it to get rid of the pleated sections in the stocker. I know why the pleats are there, I just don't like them.
I think we can add ChromerDon and his Dawg to the list of PTer's that changed their intake hose?
![]() If I hand to theorize I would say that the premature cause of many was due to owners that were more prone to get into boost and increased engine and under-hood temperatures more frequently. My personal PT had less then 50k miles when we got it and there was nothing wrong with my hose. About a year later I found the first signs of the deterioration. I replaced mine with a new hose at the hefty tune of 65.00. I may later go the way that many PT modders went like Brian aka 2step and use my own hose system with silicone boots? I already have many hoses and fitting to make up my own intake system just never got around to it yet. And yes I will post a picture tomorrow it is to late right now. LOL ![]() |
![]() Quote:
I thought maybe I had better take the pictures and post them tonight! ![]() ![]() ![]() The extra blue hose was intended for the Turbo area because this kit is semi universal and did not have enough hoses for the complete project. At the time I was enthusiastic to complete the the hard pipe systems and purchased the only hose I could find locally for the needs. I postponed building the system after I ran tests on another PT cruiser with the top of the line hard pipe system specifically designed for the PT Cruiser and found zero improvements. But that's another thread and argument among members that bought into the whole hard-pipe hype. At least for a PT 2.4 producing up to say about 300whp.
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 11 May 2016 at 12:59 am. |
What are the symptoms when this part starts to go bad? To be honest I never bothered to check mine. Too much other stuff going on.
As for the hard pipe systems, don't they have to have some rubber or soft parts in the line? The parts are going to move at different rates, especially if your (like most) mounts are bad. The system has to have at least a little give, doesn't it? Even exhausts have a decent amount of wiggle built in nowadays.
2003 GT 5 speed 162,000 miles |
![]() Quote:
My Cruiser was re-engineered for a different purpose, taking names and kicking ass. The engine torque struts were replaced with firmer ones that don't allow much movement. Thus my airbox to turbo pipes didn't need super flexible connectors. The connectors were soft silicone pieces but not with any pleats for stretching and compressing, etc. So I compromised NVH for responsiveness, traction and robustness. As is usually the case, you have to pay to play, though. |
Thread Tools | |
Display Modes | |
Turbo Coolant hose? Replacement/Hose Size | PTTuber | Tech & Performance Forum | 9 | 07 Aug 2015 05:27 pm |
Air Intake Hose..... | Pati_M | General Turbo Discussions | 4 | 02 Aug 2012 06:33 pm |
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid | 1autodr | Classifieds: Want To Buy | 1 | 24 Feb 2011 05:15 pm |
03 GT Intake hose and lower box with AirRaid Quick Intake | Pt_SRT | Classifieds: For Sale/Trade | 2 | 16 Feb 2010 06:36 am |
BTG Turbo intake--Blue hose | nbr10 | General Turbo Discussions | 0 | 08 Aug 2003 11:47 pm |
