Poor boost
Like Tree4Likes
Old 23 Jun 2016, 06:24 am
revo's Avatar
Default Poor boost
Quick question on my way to work today after putting 89 oxtail instead of 93,boost only went to 6 or 7lbs normally goes to 16 back to 13 moves up to 15lbs now it's a limited with some mods.spring mod on waste Gate never get over boost code ever.do sent seem like boost leak due to holds at 7 wot.
Old 23 Jun 2016, 08:23 am
Default Re: Poor boost
What was the question?
Old 23 Jun 2016, 08:41 am
Perhaps with the lower octane fuel, the pcm picked up some knock and limited the boost and or timing, yielding the lower numbers?
Old 23 Jun 2016, 08:59 am
revo's Avatar
That's what I was wondering problem didn't occur till I put lower octane in.I'll pull battery terminal to reset pcm and see if it goes back to were it was thanks
Old 23 Jun 2016, 09:56 am
You will need a OBDII Scan Tool to reset the engine trouble codes. The codes are still stored when you disconnect the battery cables.
Harbor Freight has OBDII Scan Tools for a reasonable price.
Search results for: 'Scan tools'
NitroPT likes this.
Old 23 Jun 2016, 10:02 am
The PT Cruiser PCM can not do that far a self adjustment compensation to the degree of information in the first response. but it is a good thought.
Old 23 Jun 2016, 10:25 am
revo's Avatar
No check engine lite on I have a snap on solstice I'll scan it when I'm done at work. And I'll check all lines and hoses but problem started after I put reservation gas in don't get paid till tomorrow went cheap first time last time
Old 24 Jun 2016, 07:36 am
revo's Avatar
All right is caned car no codes reset pcm still have 89 in it.after computer reset was boosting back to normal after a mile went back to 7lbs pinging hesitation crappie shifting. On lunch going to put 93 back in it think that's the issue I hope
Old 24 Jun 2016, 07:56 am
Fk5 Fk5 is offline
If it was pinging it should be pulling boost.
2003 GT 5 speed
162,000 miles
Old 24 Jun 2016, 08:17 am
revo's Avatar
That's what I'm figuring thanks.
poor pt jrbsr05pt General PT Cruiser Discussions 9 04 Apr 2012 10:04 pm
MY POOR PT 2k1PT Tech & Performance Forum 10 22 Aug 2008 02:24 pm
Oh my, poor PT! JolieCruiser General PT Cruiser Discussions 9 27 Apr 2008 09:47 pm
Part Throttle boost with boost controller forcedinduction Turbo Performance 2 18 Feb 2006 01:48 pm
Poor mans boost controller Jason_L Turbo Performance 2 01 Jan 2004 07:40 pm
