Ago evm Bov kit
Old 11 Aug 2016, 08:36 pm
Default Ago evm Bov kit
I need some insight on the best way to install this thing. And it didn't come with a gasket........ its a agp evm auto correct messed with the title
Old 14 Aug 2016, 01:36 am
chris15's Avatar
Default Re: Ago evm Bov kit
Uh, well, you disconnect the vacuum line on the stock one, remove the three bolts that attach it to the compressor housing, clean the surface, and use gasket material or RTV to seal the new plate to the same spot you removed your OEM plate from.
I don't have any experience with running this part, though, but it seems like this thing just vents to atmosphere instead of recirculating. The other alternative to this is the Mopar BOV, affectionately referred to as the "rice plate", or just using a block-off plate and an external blow-off valve.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
