turbo piston choice
Like Tree6Likes
Old 31 Aug 2016, 09:18 pm
jch jch is offline
Default turbo piston choice
I'm new to the forum and really appreciate the atmosphere. Very open and helpful people. I just bought a non running 04 turbo lite touring edition. I am going to rebuild the engine and was thinking of using non turbo pistons. Any thoughts? I would use a forged set if they are available.
Old 31 Aug 2016, 10:19 pm
rckstein's Avatar
Default Re: turbo piston choice
Welcome to the forum
Old 01 Sep 2016, 06:41 am
Not a good idea. The turbos have heavier internals than the non-turbos. I don't think the non-turbo pistons will hold up. I could be way off base here, but don't really think so, unless you don't ever get into the turbo. My question is why the hell would you even think of using non-turbo parts in a turbo engine? Is there something wrong with the OEM pistons? If not, put a nice cross hatch in the cylinders and new rings on the old pistons. Just be sure to clean them up first.
Old 01 Sep 2016, 07:10 am
jch jch is offline
The non turbo engines have a higher compression rate than the turbos. I know I can always add more boost but since i'm rebuilding anyway why not up the compression? As far as durability I found forged pistons online that should be better than the stock cast pistons.
Old 01 Sep 2016, 07:25 am
Just be sure to do your homework. What you're saying makes sense, but you may want to PM NitroPT and see what he has to say. He KNOWS what he's doing, no matter what some other folks may think. Dude is brilliant. He's earned my respect and that's not an easy thing to do.
Old 01 Sep 2016, 08:18 am
Fk5 Fk5 is offline
Upping the compression in a turbo car just means you won't be able to run as much boost. You will also have to screw with the tune to get it to work properly. Pretty sure that the pistons in the turbo are higher quality than the non-turbo and I would look at that swap as a downgrade.
2003 Dodge Neon SRT-4 - Engine Specifications & Overview - Hot Rod
Handy_Cruiser likes this.
2003 GT 5 speed
162,000 miles
Old 01 Sep 2016, 11:55 am
You can use non stock aftermarket pistons if you do your math. You may also notice that there is one big difference between the "turbo" pistons and the none Turbo piston. Hint ..its not the quality or compression.
I would actually recommend that you discus your engine rebuild with a Performance engine machine shop and not the internet forums.
I would post more information but I dont feel like arguing with member that have NEVER owned/operated an engine machine shop like myself.
Trust me on this one GET OFF THE FORUMS for answers!!!!
WELCOME TO THE FORUM
Old 01 Sep 2016, 11:56 am
jch jch is offline
After further research I believe that FK5 is correct. The computer would retard the timing so much I would lose performance. It's just hard to break old habits. I appreciate everyone's thoughts and look forward to asking more questions.
Old 01 Sep 2016, 12:05 pm
not exactly accurate!!!!!
Do your math formula's!!!!
Look at the knock value limitation as well the PCM fueling and timing tables on a stock PCM.
Really I can't be any clearer to you what I recommend in my first response!
But I guess the other member will be more then happy to help you from this point on.
Good luck on your adventure!
In need of a piston Bobbykeith Tech & Performance Forum 2 10 Jun 2013 09:19 am
In need of piston Bobbykeith Turbo Performance 3 09 Jun 2013 09:04 pm
Piston for turbo Bobbykeith Classifieds: Want To Buy 0 03 Jun 2013 01:04 pm
Piston Misfire Connie Tech & Performance Forum 1 16 May 2011 05:24 pm
Piston Conecting Rod loadedchainsaw Tech & Performance Forum 3 02 Mar 2011 07:12 pm
