What's a Nice Turbo Upgrade?
Like Tree27Likes
  #31 (permalink)
Old 25 Oct 2016, 12:57 pm
Fk5 Fk5 is offline
Default Re: What's a Nice Turbo Upgrade?
Originally Posted by SPLNeon View Post
You will overboost and go into limp mode if you run the stg 2 wga and the diablotune. You would need to get a CMR tuner to modify the tune to work with the stg 2 wga. In my opinion, it would be money wasted to go through that. You say that you want faster spool? These cars build boost pretty well off idle when Wot, unless there is something wrong?!
I was going to say, generally - bigger turbo = slower spool. Does your race car have a big or custom turbo yet or still stock?
Messing with the turbo can be very worthwhile, if you are honest about what you are trying to do. I have a TT Stealth and those have 2 very small turbos for quick spool. The guys that went to big turbos were actually getting better mpg because the big turbo was keeping them out of boost more at cruising speeds.
2003 GT 5 speed
162,000 miles
  #32 (permalink)
Old 25 Oct 2016, 01:36 pm
I choose Garret because few will debate information from these guys
This is a really helpful informational from them ..Garrett
*https://turbobygarrett.com/turbobyga...Tech%20101.pdf
*.....The primary input in determining which turbocharger is appropriate is to have a target horsepower in mind. This should be as realistic as possible for the application. Remember that engine power is generally proportional to air and fuel flow. Thus, once you have a target power level identified, you begin to hone in on the turbocharger size, which is highly dependent on airflow requirements......
  #33 (permalink)
Old 25 Oct 2016, 01:54 pm
SPLNeon's Avatar
I have the tiny stock turbo still. With over 315000 km on it. Spools up pretty well instantly. Has shaft play up and down, tight in and out 😝
THE UNDISPUTED KING OF THE PARKING LOT
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.95 at 118.41mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
  #34 (permalink)
Old 25 Oct 2016, 02:41 pm
Fk5 Fk5 is offline
I have the tiny stock turbo still. With over 315000 km on it. Spools up pretty well instantly. Has shaft play up and down, tight in and out ��
Guess that replacement will go beyond no-buck
2003 GT 5 speed
162,000 miles
  #35 (permalink)
Old 25 Oct 2016, 03:49 pm
SPLNeon's Avatar
Well, no, I have accumulated two spare complete turbofolds lol. One being my ported manifold that I want to do more work to at the wastegate end 👍
Fk5 likes this.
96 SOHC Neon Turbo
  #36 (permalink)
Old 25 Dec 2016, 01:02 pm
vipergts's Avatar
50 trim with supporting mods, Return line, 3 bars, Walbro 255, and a CMR tune...Proven powerful reliable setup...Fairly easy to find used on the SRT forums
Turbodude06 likes this.
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
2003 GT Turbo 162K miles...nice shape 1000 bux. crusofthebisquit Classifieds: For Sale/Trade 15 11 Aug 2016 10:01 pm
Turbo upgrade moparornocar Turbo Performance 1 23 May 2014 05:58 pm
Turbo upgrade wmiptguy General Turbo Discussions 5 13 Apr 2009 04:15 pm
FS: 1989 LeBaron Turbo Convertible..NICE! saxonburgcruiser Classifieds: For Sale/Trade 5 01 Feb 2004 03:57 pm
