What's a Nice Turbo Upgrade?
Like Tree27Likes
Old 17 Oct 2016, 02:42 pm
Question What's a Nice Turbo Upgrade?
So being new to the GT Cruiser world, and picking up s beautiful ride with lots of tasteful mods, over the winter is like to put a larger but still streetable Turbo on.. here's a list of everything done to mine to give you an idea..
2004 PT Cruiser GT
2.4L Turbo
5 Speed
New Clutch
New Slave Cylinder
New Timing Belt
New Water Pump
New 185* thermostat
New Tensioner
New plugs every 2nd oil change
New AC Tensioner Assembly
New Shocks and Struts
New Brakes
New CV Shafts
New Heat shields
New Pioneer Door Speakers with Tweets
New Kenwood Rear Speakers
New 8" factory subwoofer
Brand New Pioneer AppRadio3
Ported and polished turbofold with elbow mod
3" O2 Housing
3" Down Pipe
3" Full Exhaust All Stainless
Exhaust is heat wrapped from motor to the end of down pipe
Billet Catch Can
Triple Gauge Piller Pod
New AEM Wide Band
New Autometer Oil PSI Gauge
New Autometer Boost Gauge
New O2 Sensors
New Hurst Short Shifter
Air bags in rear with gauge
Composite Intake
Ported Throttle Body
Hard Pipes
Newer turbo charger (20,000kms on it)
K&N Air Filter
Air Box Mod
New Headlights
Hid Headlights
Hid fog lights
New 2nd Gen Tail Lights
Stage 1 PCM
Stage 1 injectors
Pteazer Roll Pan
Pteazer Cowl Hood
Fat mate insulated floor with dynafoam
Comes with a diablo sport SRT tuner( I never used it)
If you have any other suggestions please post up. Thanks
Handy_Cruiser likes this.
Scott Haverkamp
2004 PTGT
Old 17 Oct 2016, 07:29 pm
_PTGT03's Avatar
Default Re: What's a Nice Turbo Upgrade?
Upgrade your camshafts; from ebay
Brian Crower Cams Stage 4 Dodge Neon SRT4 PT Cruiser 2.4L SRT-4 Camshafts BC0163
Complete car polyurethane bushing replacement + shifter bushings; and you want race engine mount inserts
Short throw shifter (if you're manual) Maddog Shifters
04-06 PT Cruiser PCM re-program stage 2
2004-2006 Pt Cruiser
I'd recommend buying his computer software as well, so that when you have your car dyno-tuned the fuel maps can be tweaked to get more power output.
3" electronic valve cut-out that can be calibrated to a wide-open throttle position
NeedsWings Performance Products. DMH 3" Exhaust Cutout Opener
Solid flywheel conversion kit to replace the dual-mass flywheel which absorbs too much energy and is heavy. get the solid flywheel lightened and balanced before installing.
look in my signature for the part number for a limited slip differential.
obviously high quality performance tires like the michelin pilot cup series.
Keep with the stock turbo until after you try upgrading the computer software and then tuning it to get maximum results and if you're still not satisfied then you can get upgraded turbo kits but you have to shop around in the SRT-4 section maybe the stage 3 turbo upgrade for the srt-4 neon
Old 18 Oct 2016, 02:09 pm
l:
Where do you get it ?
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 19 Oct 2016, 03:20 am
_PTGT03's Avatar
rockauto - it's valeo branded. if you just pull up the car details and transmission clutch section it's in there. just a warning that the slave cylinder busted off during shipping so keep your old one just in case if there is no issue with it
Pippov likes this.
Old 21 Oct 2016, 03:40 pm
chris15's Avatar
Cams should literally be one of the last modifications on the turbo 2.4L engines if your goal is performance. There are a metric ton of supporting modifications that should be performed prior to upgrading cams, including a ported cylinder head. Anyone installing cams in the A853 engine without a ported head is simply doing it for the sound/mod list appeal. There have been fully-documented builds making 500+hp on a stock head and stock cams, with cars driven well into the 10s in the 1/4 mile. Not to mention the powerband with a stock head and stock turbo on a set of BC4s would be godawful. I didn't even go with BC4s for my build because I was concerned that I'd sacrifice too much midrange power..
Everything else, however, I agree with. I haven't had any experience with Kevin, so I can't speculate on his products, but you can easily pick up a Diablosport Predator, inTune (less preferable) or Trinity and find a reputable CMR tuner (Nigel, Duster, etc.) to tune your vehicle as well.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 21 Oct 2016, 05:09 pm
rob302's Avatar
i'm buying a 6lb heavier RAM flywheel for my Ford beater. makes for harder launches and easier low rpm moping along on the street. the cam i picked says "Good drivability down to 2100 rpm, lumpy idle, rpm range 2600-6200" the 7lb heavier one should help make the driveability tolerable at an even lower rpm, and should let me reduce the recommended idle of 950 down to 700 or so to save gas and make the lopey idle sound even more sexy.
i would not waste the money on a light weight unit for the PT as you will never rev it high enough to see any benefit... unless you're shifting at 7-8k. you will likely notice the negatives not the benefits as the PT is already overly heavy and a torqueless turd at low rpms. a heavy flywheel is a good crutch for things like that.
just trying to give advice that keeps the car fun/easy to drive around town. maybe i'm nuts.
808PTcruiser likes this.
Old 21 Oct 2016, 05:18 pm
Camshaft(s) and the choice should be a strong consideration when ever you are doing serious engine modification and what you expect to achieve for your project. No Professional Racer or Performance engine builder would leave them out of a discussion for use. Also Professional (trained) ECU/EFI Calibration Technicians will advise to get them installed before they do a custom Calibration on your Computer to get the optimal engine output. Most Performance Head Porting Shops will ask what camshaft(s) you are going to use and many will ask to have them to set up up specifically for the Performance head work contracted.
The best advise when camshaft(s) are considered is to talk to the shop that is doing your Performance Engine or head work for advise or even better the camshaft manufactures direct. The better one will ask that you fill a very detailed questionnaire about your engine, drive-train, etc.
John Force Racing - The Official Website
The internet is an interesting place to find the information that agree's with the seeker and not necessarily what is factual and often times simply exaggerated.
Old 21 Oct 2016, 05:26 pm
Mike aka Thuimper460 will gladly go into more details about head porting and cam(s).
Thumper Performance
Pippov likes this.
Old 21 Oct 2016, 05:34 pm
rob302's Avatar
post some pics of the car and the parts. we like stuff like that over here
Old 21 Oct 2016, 05:54 pm
Handy_Cruiser's Avatar
+1
Yep. I want see this bad boy. That's a lot of mod work that most PT owners don't do anymore.
2003 GT Turbo 162K miles...nice shape 1000 bux. crusofthebisquit Classifieds: For Sale/Trade 15 11 Aug 2016 10:01 pm
Turbo upgrade moparornocar Turbo Performance 1 23 May 2014 05:58 pm
Turbo upgrade wmiptguy General Turbo Discussions 5 13 Apr 2009 04:15 pm
FS: 1989 LeBaron Turbo Convertible..NICE! saxonburgcruiser Classifieds: For Sale/Trade 5 01 Feb 2004 03:57 pm
