quote:Originally posted by Gunner
I took the PT out for a good little romp today. During my drive I pulled over and stuck my head under the car to check the area where the condesation appeared to be coming from before. There was no dripping at all. I'll keep my eye on it and let you know if anything changes. THANKS for your replies!!!!!
My Point was, if you're leaking water from the middle of your exhaust, then you're also leaking exhaust. There is not a tight seal there. Next time you get in it for the first time, start it up and then feel all around where the leak is. I'lll bet you feel exhaust coming from that spot. Now, it may not be much to worry about, and may not be worth fixing, but it is a leak. Personally, it would drive me batty. I would either weld that connection, or at least reassemble it with muffler sealant and allow it to cure before driving. Just my 2 cents!
Harry
