BOV Install, Other than MOPAR?
Old 18 Jun 2004, 11:54 pm
LAF LAF is offline
Default BOV Install, Other than MOPAR?
So who has installed an aftermarket BOV. Was wondering what one? How did you do it?
Any help is apperciated.............
Old 19 Jun 2004, 02:08 am
Although not exactly on topic, thought this PDF might be helpful to those considering intalling the Mopar BOV which, for the money, is probably the best buy available, from all I have read.
http://www.lake-effect-racing.com/SR...DF/BOV-Kit.pdf
Old 19 Jun 2004, 04:22 am
Ive got the TurboXS RFL installed in the stock UCP and tapped into the TB.
6 washers, doesnt seem to leak like some others with RFLs.
Got it from AGP turbo, with the connector pipe and block off plate.
Had pics, but my Cardomain site got screwed up - all the pictures are gone!!
On this site my sig and link are gone too...
Email me if you want the pics.
Rob
Click to see my GT!
Old 19 Jun 2004, 06:44 am
LAF LAF is offline
The reason I want away from the MOPAR is I dont think is up to the task With a Greddy B II and turbochargers.com waste gate. I have BOP on its way and will have a Mopar BOV for sale as soon as I sort this out.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Old 19 Jun 2004, 02:15 pm
I have a HKS SSQV bov. It was mounted on the factory UCP but is now mounted on Adam's UCP.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 19 Jun 2004, 02:51 pm
I would be interested in the details on this, Rob. I had only seen a site that said to install this unit in the pipe that runs under the engine, which makes lubing it and keeping it clean hard at best.
Rob
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 20 Jun 2004, 09:39 am
Send a message via AIM to sakigt
What kind of boost do you want to run? The mopar should be fine to handle 16-18 psi Id think...Youre worried about leakage right?
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 20 Jun 2004, 02:37 pm
LAF LAF is offline
Sakigt,
Yes. And I read that the after markets are doing a better job. Just looking for info and thoughts is all.
Old 20 Jun 2004, 02:59 pm
Just thinking the cost of the pipes + the BOV could get a little pricey for only a little better performance-wise.
Now if you're looking for a cooler sound...thats a different story. Anything is better than our "sneeze."
Old 21 Jun 2004, 12:00 pm
LAF -
An aftermarket BOV will hold more boost.
Rice_Killing_GT has the Turbochargers.com WGA with Mopar BOV -
quote:
Part throttle (3-3.5k) boost is around 7psi with no surge. I'm putting the stock airbox back on, it's just too loud and gonna put an HKS Bov on the Mopar one is just one loud pppppppppsssssssssssssssshhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh, I swear it last that long sometimes, it's annoying.
I had the same until I added all 6 washers to the RFL BOV. Now only blows off over 5-6lbs.
BTW I also have the Turbochargers.com WGA.
TripleJack - my RFL is installed on the cold side, like where Mean Green has his HKS.
Doesnt get wet or dirty in this location. Has not required any lube yet.
I believe you are correct, though, on the hot side, under the engine would probably be better.
Best place is as close to the turbo as possible.
Edit - Heres mine -
Rob
Click to see my GT!
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
MOPAR sub - where is install on PTDIY.net? CraigO Exterior & Interior Styling 1 08 Jun 2004 06:54 pm
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
Mopar Parts Now Available For Dodge SRT4 skylight PT Cruiser News and Rumors 5 10 Sep 2003 10:33 pm
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
