Overheating issue
Old 02 Mar 2017, 05:54 pm
Default Overheating issue
Can someone advise where the fan relays are as the fans are not
Kicking in And car gets hot in traffic???
Old 02 Mar 2017, 06:00 pm
Fk5 Fk5 is offline
Default Re: Overheating issue
No need for a 2nd thread. That is bad form. It was answered in the very first response. Go back there and read the responses. Your fix may be simple, but it won't be popping in a new relay. If you had a different model you would have to tell about the year because they were in different places. Some on the shroud.
2003 turbo GT fan relays
Welcome to the forum.
The 2003 GT does not have any fan relays.
Turbo Radiator Fan
The radiator cooling fan is a variable speed electric motor driven fan. The radiator fan assembly includes an electric motor, fan blade, and a support shroud that is attached to the radiator. The radiator fan is serviced as an assembly (fan motor/fan/shroud).
The variable speed radiator fan is controlled by the Powertrain Control Module (PCM) by way of a Pulse Width Modulated (PWM) signal. The duty cycle ranges from 30% for low speed operation then ramps-up to 100% for high-speed operation. This fan control system provides infinitely variable fan speeds, allowing for improved fan noise, A/C performance, better engine cooling, and additional vehicle power.
To control radiator fan operation, the PCM looks at inputs from:
Engine coolant temperature
A/C pressure transducer
Ambient temperature
Vehicle speed
Transmission oil temperature (automatic transmission only)
From the 2003 shop manual for the 2.4 liter Turbo:
Harness connector viewed from open end with the locating-locking tab at the top.
Top right is pin #1
Top left is pin #2
Bottom right is pin #3
Bottom left is pin #4
#1- black 10 gauge wire- ground
#2- violet/red 10 gauge wire- battery positive (fusible link)
#3- dark green/orange 16 gauge wire- auto-shutdown relay output
#4- dark blue/dark green 20 gauge wire- radiator fan motor control (part of PCM)
I would suggest checking the engine temperature sensor if the radiator fan is not getting any signal from the PCM on #4. Other members have had the engine temperature sensor fail causing the radiator fan not to work properly.
2003 GT 5 speed
162,000 miles
rckstein's Avatar
Wasn't your question answered in your other thread?
Overheating issue ted400 General Turbo Discussions 5 10 Oct 2013 12:10 pm
Overheating issue. Help. anthonyb529 Tech & Performance Forum 17 14 Feb 2012 04:32 pm
Overheating Issue Spekstacular Tech & Performance Forum 5 05 Sep 2011 08:41 pm
Overheating issue... derek02PT Tech & Performance Forum 6 22 Jul 2011 12:45 am
Overheating Issue decyferite General PT Cruiser Discussions 2 17 Jun 2010 10:51 pm
