PT Cruiser Forum Car Videos
Car Rims
New sport compact says....
Old 26 Jun 2004, 09:23 am
sakigt sakigt is offline
Send a message via AIM to sakigt
Default New sport compact says....
The only gains they saw after putting an exhaust in the SRT-4 was due to the loss in backpressure, the change in boost seen was controlled back by the PCM. At best they saw 5hp. That 5hp is only seen when you drive your car haed all the time...to teach the PCM that is "normal"
Looks like Stage I and a map clamp is the way to go...
Thoughts?
Old 27 Jun 2004, 09:50 am
hyracer hyracer is offline
Skagit,
I'm no expert on this but here is my two cents worth and what I have gleaned out of the SRT4 forums...
The Mopar cat-back exhaust is not needed until you go ABOVE Stage 1 boost levels. Mopar recommends upgraded exhaust to get the advertised HP ratings from Stage 2.
You do not need a MAP Clamp unless you run above 15 lbs. boost. Stage 1 will get you to 15 lbs. boost but the timing is not pulled back until you go above that level. That's why you see people claiming to run 16-18 lbs. boost but there quarter mile times are still low...they are making more boost but the timing is pulled back so far they are still making roughly the same HP.
So if you want to make more power than Stage 1 (w/o nitrous or other power adders)you need five things:
1. Stage 1
2. Manual or Electronic Boost Controller. The electronic is the best as it gives you more tuning ability. I plan on buying the GReddy Profec B Spec II from Hector at Exhaust Depot
3. A MAP Clamp set between 4.2-4.3 volts
4. An adjustable waste gate set to 13-14 lbs. boost. TThrift will have one for the PT available soon.
5. The Mopar/Borla cat-back exhaust or equivalent
Those five things when set up properly should give you Stage 2 or higher results.
Deen
Old 27 Jun 2004, 10:52 pm
ptgtcb ptgtcb is offline
Thoughts?
The srt-4 exhaust is already straight through from the factory.
I did not see the article did they replace the CAT as well?
Lets see sport compact mod a PT GT!
vB code is On
19's and eibach sport spring drop superjes001 Wheels, Tires, Suspension 2 24 Feb 2006 06:59 pm
Oct 5th CSCS Sport Compact Drag at Cayuga GT_Firebreather Canada PT Forum 0 16 Sep 2003 01:19 am
Sport Compact Magazine turbo article THier General Turbo Discussions 5 03 Sep 2003 10:20 pm
H & R Sport Springs Grouch Tech & Performance Forum 8 06 Jul 2003 03:23 pm
Anyone ever installed aftermarket sport seats? ldslifter Exterior & Interior Styling 6 12 May 2003 08:29 am
  Debt Help | Rapidshare eBooks Download | Fast Loans | Online Loans | Free Myspace Layouts
