PT Cruiser Forum Car Videos
Custom Wheels
reset computer
  #11 (permalink)
Old 18 Aug 2004, 04:46 pm
CarolinaBlue_GT CarolinaBlue_GT is offline
quote:Originally posted by Cal Cruzer
Just disconnect the negative (ground) terminal.
Thanks for the quick reply! [^]
So it's normal ~not~ to lose your radio's presets, then?
Mike
2003 Patriot Blue GT
\"R\" Package
Autostick
K&N drop-in w/both airbox silencers removed
Brand \"X\" Turbo-up pipe
  #12 (permalink)
Old 18 Aug 2004, 08:18 pm
Wingdale Dave Wingdale Dave is offline
Right....
...As long as you don't step on the brake pedal while the battery is disconnected. Doing that will reset all.
All I need is more time and more money.
  #13 (permalink)
Old 19 Aug 2004, 08:56 am
quote:Originally posted by Wingdale Dave
Right....
[:0]
Whoah! Now that's intriguing! Thanks for the heads-up. I never did hit the brake pedal, so that must have been why I was able to keep everything.
Thanks for that little tidbit! [?]
Mike
\"R\" Package
Autostick
  #14 (permalink)
Old 19 Aug 2004, 09:14 am
Mojito Mojito is offline
Does it reset the mileage too? []
BTW, if I put stage 1 pcm, is it possible for a dealer to determine if it's stage 1 or stock without looking at the lables? Is it visible when reading error codes or some other way?
2004 Electric Blue GT 5-Speed
  #15 (permalink)
Old 19 Aug 2004, 05:25 pm
JPMS GT JPMS GT is offline
Mojito, it only resets the trip odomoiter not the total mileage. I put on the green wheel disconnect that maakes the reset easy. When I installed the AirForce One intake it said to disconnect the negative terminal and turn on the headlights for one minute. Then turn the lights off and reconnect. I notice more responsive shifts and starts after I do it. [8)]
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
  #16 (permalink)
Old 19 Aug 2004, 08:16 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
If you remove the 4 rainbow inspired pieces that attach to the PCM you can reset only the PCM, not the entire car. ie) radio and stereo settings wont be affected
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
  #17 (permalink)
Old 20 Aug 2004, 12:30 pm
Thanks SakiGT,
But now that you've thrown THIS into the mix!...
Once you disconnect the pieces you've described, does it result in an instant PCM reset, or do you still need to leave it disconnected for a set amount of time? [:I]
Oh, and BTW - I LOVE this place! [?]
Mike
\"R\" Package
Autostick
  #18 (permalink)
Old 20 Aug 2004, 04:50 pm
SakiGT, how did you know that? CarolinaBlue, be careful in disconnecting the 'Raindow inspired' connectors to the PCM. When I installed my S I the part that took the longest was getting the connectors off after I moved the red locks. It could have been that it was the first time they had been off but it took a while to figure out the pull out and down required. Somehow I broke one of the locks when I replaced it so now I just use the battery reset switch. [?]
  #19 (permalink)
Old 20 Aug 2004, 06:05 pm
Actually my ex boyfriend did it one day b/c it made sense to him. Made sense to me and worked so there ya go
  #20 (permalink)
Old 23 Aug 2004, 09:06 pm
GR8FLPT GR8FLPT is offline
Does this resetting apply to auto transmissions only or does the 5-speed get the same benifits? I have done it on my 01 but not my GT 5-speed yet...[:I]
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
vB code is On
Wanted: 03-05 Turbo computer 5 speed 340x Classifieds: Want To Buy 2 20 Dec 2005 11:22 pm
Computer Help?!!! jmack Non-PT Discussions 8 12 Jan 2005 01:57 am
Computer reset question... smfrycruzr General PT Cruiser Discussions 4 27 Jun 2004 09:02 pm
intake - must reset computer? got dyno numbers? secretspy Tech & Performance Forum 4 16 Jul 2003 06:22 pm
New Here - With a Computer Question... Martin Logan Tech & Performance Forum 1 12 Nov 2002 12:12 pm
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  Car Accident Lawyer Los Angeles | Samsung | Loans | Loans | Loan
