BWS
Like Tree4Likes
  • 2 Post By CREWZIN
  • 2 Post By OurPTGT
Old 23 Mar 2017, 03:53 pm
Default BWS
Anyone running a bad setup???? If so what brand?
Old 23 Mar 2017, 06:07 pm
Default Re: BWS
BWS
What causes Beckwith-Wiedemann Syndrome (BWS) and who is affected?
The causes of BWS are not always fully understood, although genetic testing has shown many patients to have changes in the genes of chromosome 11. Beckwith-Wiedemann Syndrome has an estimated occurrence of one in 14,000. BWS has been documented in many different ethnic groups from around the world and occurs equally in males and females. Some cases of BWS are inherited, but most are sporadic.
Old 26 Mar 2017, 12:09 pm
Default Re: BWS
Originally Posted by CREWZIN View Post
BWS
Big wheel stock look it up I've seen srt4s with them and I was wondering if anyone put one on a cruiser
Old 26 Mar 2017, 01:04 pm
rob302's Avatar
Default Re: BWS
this guy:
Originally Posted by mole View Post
I still make and sell BWS. I'm putting one on my 05 GT auto for some #s for you guys.....
but the promised numbers never came. he seems to have vanished into thin air. not sure if he's sick, hiding, dead, etc.
Old 26 Mar 2017, 01:09 pm
rob302's Avatar
Default Re: BWS
you can find him on FB but the top post is a link to a forum review saying a BWS blew up after 4000 miles.
https://www.facebook.com/search/str/..._blended_posts
i wouldn't want one..
Old 28 Mar 2017, 07:11 am
Default Re: BWS
BWS you say
I forget how many miles I put on it and I added a few other mods at the same time i think.
Never dyno'd.
I did crack into the 13 second club with it though and had several 13.5-13.6 passes with the best being a 13.4 something. A shame I never got the S3 to the track. Was working with Duster360 over at SRTForums to get a base DSP email tune when the trans gave up the ghost back in 2010?
Turbodude06 and rob302 like this.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 16 May 2017, 10:06 pm
Default Re: BWS
Hello
You can get one fromTurbobayperformance , he does some great jobs on turbos
(FTW-69XR) Dodge Neon SRT-4 "BWS" | Turbobay Performance.LLC
Should go for the bigneck manifold too
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 17 Aug 2017, 06:51 am
vipergts's Avatar
Default Re: BWS
Unless your doing supporting mods, exhaust, 3 bar map/tip, FM WGA or similar, hand held tuner with a custom DSP tune, Walbro 255, AFR gauge, electronic boost controller, its a waste of money
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
