Blow off valve - Questions
Like Tree5Likes
  #21 (permalink)
Old 28 Mar 2017, 11:22 am
Handy_Cruiser's Avatar
Default Re: Blow off valve - Questions
Originally Posted by OurPTGT View Post
I've been out of the game for some time but IIRC, the factory recirculating valve directs hot air back into the INTAKE flow not exhaust. Also IIRC, there was some concern early on about that redirected HOT air being mixed into the cool intake air.
EDIT: I should have read the entire thread first before posting
That's okay. The post needs correcting.
I suspect Rob is right as to why this turbo is designed this way. Let's look at the problem of heat with boost.
The theoretical outlet temperature for an industrial blower = Inlet temp. x (pressure in Bars)^0.286.
For our "quackilations", we will need our temperature in Kelvin. So 77 degree F becomes 298 degree Kevin.
So let's "quackilate" some boost temporatures using Arkansas 6th grade math.
Boost
psi------->Bars (atmospheres)...................................Bo ost Temp.
0--------->1.00…………………….. 298 K x (1.00 Bar)^0.286 = 298.0 K
5--------->1.34…………………….. 298 K x (1.34 Bar)^0.286 = 324.0 K
6--------->1.41…………………….. 298 K x (1.41 Bar)^0.286 = 328.6 K
7--------->1.48…………………….. 298 K x (1.48 Bar)^0.286 = 333.1 K
8--------->1.55…………………….. 298 K x (1.55 Bar)^0.286 = 337.4 K
9--------->1.62…………………….. 298 K x (1.62 Bar)^0.286 = 341.6 K
10-------->1.69…………………….. 298 K x (1.69 Bar)^0.286 = 345.7 K
11-------->1.76…………………….. 298 K x (1.76 Bar)^0.286 = 349.6 K
12-------->1.83…………………….. 298 K x (1.83 Bar)^0.286 = 353.5 K
13-------->1.90…………………….. 298 K x (1.9 0Bar)^0.286 = 357.2 K
14-------->1.97…………………….. 298 K x (1.97 Bar)^0.286 = 360.8 K
15-------->2.03…………………….. 298 K x (2.03 Bar)^0.286 = 364.4 K
16-------->2.10…………………….. 298 K x (2.10 Bar)^0.286 = 367.9 K
Boost
psi............................................... Temp in F
0---------------------->298.0 K = 77.0 degrees F
5---------------------->324.0 K = 123.8 degrees F
6---------------------->328.6 K = 132.2 degrees F
7---------------------->333.1 K = 140.2 degrees F
8---------------------->337.4 K = 148.0 degrees F
9---------------------->341.6 K = 155.5 degrees F Turbo Lite
10--------------------->345.7 K = 162.8 degrees F
11--------------------->349.6 K = 169.9 degrees F
12--------------------->353.5 K = 176.8 degrees F PT GT
13--------------------->357.2 K = 183.6 degrees F
14--------------------->360.8 K = 190.1 degrees F
15--------------------->364.4 K = 196.5 degrees F PT Stage 1
16--------------------->367.9 K = 202.8 degrees F
We could instead use the blower efficiency equation: Outlet Temp. = Inlet Temp. in K + [[Inlet Temp. in K x (-1 + (Outlet Pressure in psi /Inlet Pressure in psi)^0.263)] / Efficiency].
Let's say efficiency is 70%
Boost
psi................................Temp in F
0---------------------->77.0 degrees F
5---------------------->138.3 degrees F
6---------------------->149.2 degrees F
7---------------------->159.7 degrees F
8---------------------->169.8 degrees F
9---------------------->179.6 degrees F
10--------------------->189.1 degrees F
11--------------------->198.3 degrees F
12--------------------->207.2 degrees F
13--------------------->215.9 degrees F
14--------------------->224.4 degrees F
15--------------------->232.7 degrees F
16--------------------->240.8 degrees F
This is all my work. So please check my math.
  #22 (permalink)
Old 28 Mar 2017, 12:00 pm
rob302's Avatar
but when air is rapidly decompressed, it cools. so the air that was heated when compressed would be expected to cool at the same rate when unpressurized back into the intake. adiabatic heating when compressed, adiabatic cooling when decompressed..
so any BOV benefit related to temperature and recirculated air is a neat thought, it may not be the actual case, or at least not to the effect you'd expect once science gets involved.
https://en.wikipedia.org/wiki/Adiabatic_process
i make signs though.. i could be wrong.
  #23 (permalink)
Old 28 Mar 2017, 12:39 pm
Signs or no signs, I still say you are smarter than the rest of us here.
If we knew the size of the opening back into the turbo intake side, we could calculate this to see what kind of expansion (and resulting temperature) we actually get.
When you consider that the throttle will be closed at this point and forward air flow will be reduced to whatever is metered by the idle air control valve, I wonder if the turbo bypass valve creates back flow in the air filter for at least a moment?
blow off valve SuperGirl Tech & Performance Forum 24 25 Apr 2013 08:57 pm
Blow off valve. Turboguy85 Turbo Performance 6 03 Feb 2012 12:49 pm
blow off valve question reaper121 General Turbo Discussions 5 21 Feb 2009 05:12 pm
what is a blow off valve careyk General PT Cruiser Discussions 3 17 Apr 2008 02:23 pm
Stock blow off valve DMW General Turbo Discussions 8 12 May 2005 07:08 pm
