Best Air Filter assembly for Turbo?
Old 29 Jun 2004, 04:20 pm
Default Best Air Filter assembly for Turbo?
Hi all,
Looking at the various options for the air filter assembly. I like the idea of having a CARB approved unit like the K&N so I do not have to change it out at Smog Check time, but if it is not CARB I can live with it.
Thanks
Mike
Old 29 Jun 2004, 04:56 pm
If you are considering eventually installing STAGE 1 then I'd recommend you stick with the "stock airbox' with these modifications...install drop-in K&N performance air filter...replace stock turbo to airbox pipe (thereby removing the restrictive silencer in the tube) with a Brand X (amx1397)/or other custom turboup pipe...AND, remove the "white donut silencer" in the top of the stock airbox. These MODS will all help your turbo engine to "breath better" and some performance gains will be achieved. From all I have read the STAGE 1 was "designed for optimum performance" using the stock airbox setup. Together with a performance free-flow exhaust system, this worked for me. [8D] [8)] By using the SEARCH FEATURE of this forum you can find many threads with good information/PICS to help you in making a decision. Good luck.
Old 30 Jun 2004, 02:00 am
Thanks Gary.
You answered several questions. I am not planning on going to stage 1 at this time, I think my cruiser will be a commuter, with just enough pep to keep my happy. I was thinking of what I could do for bolt on HP, so the airbox/filter were the first things that come to mind. Later I may add a muffler or CatBack system, but want to keep it quite.
I may just removed the silencers and replace the pipes as you suggested, and go with the drop in, unless a filter/air intake pipe makes more sense for my driving style,
I was sold on the K&N, but wanted to check here first. All the info is GREAT.
Mike
Old 30 Jun 2004, 02:30 am
quote:Originally posted by nozzano22
Thanks Gary.
Mike
Make sure you add a flow through exhaust. Turbos love a flow through exhaust. They don't like chambered mufflers because of the back pressure.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 30 Jun 2004, 12:49 pm
quote: I think my cruiser will be a commuter, with just enough pep to keep my happy.
FAMOUS LAST WORDS...just before they start ordering stuff
Old 30 Jun 2004, 04:57 pm
Send a message via AIM to sakigt
Thanks Gary.
Mike
...every turbo that ISNT controlled by mopar, that is...
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 30 Jun 2004, 04:58 pm
You got that right CAL. I've got Eibach on my mind![8)]
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
Cabin air filter AlmondTurbo General PT Cruiser Discussions 44 27 Jul 2012 06:31 pm
Compare/contrast Air Filter Elements andym Tech & Performance Forum 7 02 Jul 2004 11:02 am
Oil & Filter Change. one_fast_pt General Turbo Discussions 13 17 Jan 2004 02:32 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
