hesitation when accelerating
Like Tree4Likes
  • 1 Post By chuzz
  • 3 Post By Fk5
Old 22 May 2017, 04:44 pm
Default hesitation when accelerating
Hello everyone, my name is Mike and I am new to this site. I have read some arricles here before that have helped, but now I am at a loss. I have a 2005 PT Cruiser GT with 99,000 miles. About 3 months ago I had a cylinder misfire code and replaced the coil pack and plugs. Has been running good until the last 2 weeks. I have a hesitation when I accelerate in the 3500 to 4000 rpm range. Also at idle when i step on the gas it will hesitate. When stopped at a light it will chug intermittantly and lurch forward a little. So far I have replaced the crankshaft position sensor and the cam position sensor. The chugging when at a stop seems to have stopped but the acceleration problem remains. Any suggestions would be greatly appreciated.
Old 22 May 2017, 11:51 pm
_PTGT03's Avatar
Default Re: hesitation when accelerating
100k miles should be the time period to remove and clean the injectors. i wonder if that's the problem. i'd look into it. or, there's a problem in the path to current for the coil driving circuits, like a high resistance. do you use 91 octane or higher fuel ?
Old 23 May 2017, 07:05 pm
I have used 91 octane since I bought the car a couple years ago. I am learning as I go, so how difficult of a task is it to remove and clean the injectors? Thanks for the suggestions!
Old 24 May 2017, 07:43 am
Before pulling the injector, why not go to Walmart and grab a bottle of Techron Fuel Injector Cleaner? I've been using it for years and have never had a fuel injector problem. One bottle about every 10,000 miles has worked just fine for me.
JonN likes this.
Old 24 May 2017, 04:21 pm
JonN's Avatar
I've been using it 5 years. No problems either.
2016 Jeep Patriot Sport 2.4L 6 speed auto 97k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 24 May 2017, 04:23 pm
Fk5 Fk5 is offline
FWIW, I haven't been using Techron for years. I haven't had any injector problems either.
2003 GT 5 speed
162,000 miles
Old 24 May 2017, 07:13 pm
Thank you all for the advice. I will give it a shot.
Getting some vibrations when accelerating..2007 PT dano4193 Tech & Performance Forum 7 05 Sep 2015 07:58 pm
Loud when accelerating vpoole28 General PT Cruiser Discussions 4 11 Aug 2015 05:16 pm
04 PT, jerking when accelerating solluna975 Tech & Performance Forum 9 08 Feb 2014 11:45 pm
vibration when first accelerating PurpleMoo41 Turbo Wheels/Suspension/Handling 7 05 Aug 2011 06:24 pm
Brake light comes on when accelerating kmancrx Tech & Performance Forum 11 02 Dec 2009 09:33 pm
