03 pt cruiser 2.4L turbo rough surging idle
  • 1 Post By _PTGT03
Old 19 Jun 2017, 02:20 pm
Default 03 pt cruiser 2.4L turbo rough surging idle
Hello I just had to do a head swap for my 2.4L turbocharged pt cruiser. New head with valves and springs, replaced oil pump, water pump, plugs and wires, coil pack and timing belt. Car say sat for a few months because the head got warped due to high temperature cause oil pump went out. Now that I have it running it has a surging idle that I can't figure out. All vacuum lines seem to be fine no cracks or wear. When I take the vacuum line off the brake booster the vacuum just surges instead of a steady sucking. Has anybody ran into this problem or might now of which route I should take now?
Old 20 Jun 2017, 08:55 am
_PTGT03's Avatar
Default Re: 03 pt cruiser 2.4L turbo rough surging idle
This is just the engine controller trying to adjust the idle air control valve to reach target idle but they'res a vacuum leak somewhere causing this problem. Very likely to be caused during the assembly and maintenance process. See about pressurizing the intake manifold and spraying a soap/water leak detector around any metal-to-gasket surfaces
Handy_Cruiser likes this.
Old 20 Jun 2017, 10:22 am
rob302's Avatar
i would recommend you unhook the electrical connector to the IAC and see if you can spot the leak and do vacuum diagnostics with it unplugged/not surging. i don't know that this is a proper way to do things, but it's usually helpful to me
Old 20 Jun 2017, 01:10 pm
[QUOTE=_PTGT03;658013]This is just the engine controller trying to adjust the idle air control valve to reach target idle but they'res a vacuum leak somewhere causing this problem. Very likely to be caused during the assembly and maintenance process. See about pressurizing the intake manifold and spraying a soap/water leak detector around any metal-to-gasket surfaces[/QUOTwQUOT
Would a leak between intake/exhaust in the head cause these symptoms?
Old 20 Jun 2017, 01:14 pm
I'm also interested in the selinoids on the passenger side above the shock tower I can't find any information on them all I know is they feed the throttle body turbo and hook up to the brake booster.
Tags
2.4l turbo, surging idle
Rough Idle again..04 auto no turbo drumrooster Tech & Performance Forum 8 07 Nov 2014 12:17 am
04 non-turbo AC / rough idle issue CA818PTCruiser Tech & Performance Forum 4 18 May 2013 03:38 pm
Surging idle 2003 turbo ricketts Welcome New PT Cruiser Members 0 13 Apr 2013 05:30 pm
rough idle and surging KIMS CRUZER Tech & Performance Forum 5 25 May 2011 12:19 pm
2005 Turbo Rough Idle Suddenly MPG Terrible MimisMom Tech & Performance Forum 6 04 Aug 2009 06:13 pm
