Engine Fan Error Code
Old 26 Jun 2017, 02:26 pm
Default Engine Fan Error Code
Question on issue to see if anyone has ever seen this.
I have a 2003 PT Cruiser Turbo, and have recently experienced a interesting electrical issue. The car will be working fine, then suddenly the battery light comes on, and then the engine light comes on. When I read the error codes, it says a 480 error as a stored code which is a engine fan error code. The car continues to run fine. The battery light clears next time you start the car and the engine light eventually clears, the engine fan appears to be working and the car never seems to have any issues through all of this. Anyone have a idea as to what may be causing this?
Old 26 Jun 2017, 02:43 pm
Default Re: Engine Fan Error Code
Your radiator fan brushes might be wearing out or shorting out causing the battery voltage to go down.
I would suggest checking the radiator fan plug connection. Make sure you are making good contact. If the connection is good I would suggest getting a battery load test done. Make sure the battery and battery charging system is working properly. Make sure the wiring harness going to the radiator fan is not rubbing on the chassis shorting the wires to ground.
Does the idle get rough when you are turning on the A/C with the engine cold?
Has the radiator fan been replaced or is it still the original radiator fan?
By the way the radiator fan for the 2003 turbo is a variable speed radiator and it is expensive so its important to make sure everything else has been checked out before replacing this radiator fan.
Old 27 Jun 2017, 07:45 am
Yes the idle gets rough when the A/C is running when the engine is cold. Is this a clue to something?
The fan has never been replaced, but appears to work.
I'll check all the connections and wiring this weekend.
Thanks for the suggestions, I'll post another reply once I do all the checks.
Old 27 Jun 2017, 10:07 am
VsandFords's Avatar
Welcome to the forum from Texas.
Please go to the new members section and start a thread telling us more about your cruiser and yourself.
Old 14 Aug 2017, 11:33 am
I was getting the 480 code a lot earlier this year and last. It seems to have stopped after I cleaned the ground connections within the car (left and right side fender ground points).
However, there is potentially an issue in that my engine tends to run cooler these days (based on the inaccurate gauge, not ECT reading from the OBDII). I was suspecting that maybe my fan's variable speed was not working and I was just getting full-on or full-off operation from the fan. I am no so close to getting rid of the car (240K) that I am no longer inclined to get to the bottom of things.
\'03 GT - No mods
\'05 Convertible Touring Ed. - No mods
Old 14 Aug 2017, 12:40 pm
Thanks for coming back and letting us know what fixed your P0480 with a 2003 turbo variable radiator fan. With that radiator fan being difficult to diagnose this will be a helpful tool to check the ground points on the fenders.
Tags
engine electrical
engine trouble, no error code apsenniel Tech & Performance Forum 10 05 Aug 2012 08:08 pm
Error Code P0303/Check Engine Light ohiomas Tech & Performance Forum 1 10 Apr 2011 02:47 pm
Engine Light ON - no error code PeeTeeCruizer Tech & Performance Forum 2 23 Oct 2010 02:32 pm
Engine light P2097 error code help jbh1860 Tech & Performance Forum 2 20 May 2009 12:30 pm
P0325 Engine Error Code on 2003 PT Turbo intim3 General Turbo Discussions 0 12 Aug 2007 08:06 pm
