Also, I don't know exactly what the DS does in regards to the RPM and speed limiter. I have a DS Intune, but to be honest never use it so I don't know exactly what it does. SPLNeon races his 03 with a DS all the time, so he would be the guy to ask about that.
Sounds like it might be simpler and cheaper to just tune my orig 03 pcm with the DST. Then get another pcm after race and send it off. Does the Mopar 03 Stage 1 pcm have the updated tables like the 04up or is it the same tables as my orig pcm. Thinking it might still control the fans.
Yes, since the stage 1 must use the newer NGC3 hardware, it will have those benefits because of that newer hardware. The stage 1 programming will make use of the higher resolution maps and ensure that it will function properly in the 03 car operating the fan as normal etc.
Well got the DST in. Backed up the original calibration. Then modified the stock tune. Raised the top speed to 150. Then took it to dyno for a baseline. Still haven't heard back from Cindy or Syked. With everything stock except for k&n typhoon intake and the BOV plate. It went 210.7hp @4950 and 234.8ftlb @4350. It started cutting out above 5000rPM. OEM wires and plugs.
I was surprised. I expected maybe 175-180hp @wheel. I pulled the pcm when I got home to see if there looked to be anything out of the ordinary. It has been changed. The bolts had all been removed at least once. The pcm itself looked almost new. Paint was nice. Aluminum looked fresh. No oxidation. It also had nice fresh stickers on it. One sticker on the side said at the top. (Upgraded software installed). I'll take it back out and get a picture when I get a min. Edited- I was running 100% 91 octane gas during the run. And after disassembly it still had the pink injectors. pt dyno.jpg Last edited by zztunnell; 17 Sep 2017 at 08:12 am. |
Found a broken vacuum line coming off what I'm gonna call the 'red solenoid. I cant find anywhere this should be hooked to. Anyone know where this is supposed to go?
Sorry double post.
![]() Quote:
Wow. If you were getting 210.7hp on the existing 2003 PCM tune (not one of the DS canned tunes), it sounds like you may already have a non-original PCM. From what I've seen, all of these PCM's have the updated software sticker. If you will post both the part number on the front of the PCM and the update part number, we may be able to look it up and tell what PCM you have there if it's stock and hasn't been reflashed already. Plus, the DS will give you the "ID Number" of the current flash in the PCM. Post that and may be able tell if it's been flashed to Stage 1 already. Also, we could like tell a lot if we knew what your peak boost pressure was. And thank you for posting these results. This will be very helpful to others in the future working on the same type of thing. ![]()
![]() Last edited by Handy_Cruiser; 15 Sep 2017 at 07:53 am. |
That's what I was thinking on the pcm. I'm on the road. When I get back in I'll pop the pcm back out and take some pics. The diablosport showed a peak of 14.31 on the way to the dyno. No tune just using the DST to monitor a few things on the way there. When I put the 91 octane tune in on way back I noticed it read 17.11 peak on one 0-60 run.
Anyone know what that white vacuum line on the red solenoid goes to? |
Got all the upgrades installed. Barely made it to the race. I had a few issues. I'll cover it all in my build thread. The car didn't have any power after 1-2 shift using the 91 tune. I switched to the stock tune and it ran good but it was pig rich at work. After a 2 successful passes. I put in some race gas to bump it the Oct above 93 and installed the 93 tune. Ran WAY better but still rich at Wot.
Who does or where can I get a custom tune made? I have an AEM wideband. I'll be hooking the output up to the DST this weekend so I can datalog. Edit- The place that did my baseline dyno runs is not familiar with the DST so they are out of the question. |
Thread Tools | |
Display Modes | |
To flash or not to flash? | Shiniquiet | General PT Cruiser Discussions | 3 | 03 Jun 2010 06:42 pm |
PCM Flash | Deborah45 | Tech & Performance Forum | 0 | 20 Apr 2010 11:30 am |
Blow off on an ATX autostick? also other questions. | kandem | General Turbo Discussions | 28 | 20 Aug 2009 06:47 am |
Flash where ya at? | OurPTGT | General Turbo Discussions | 2 | 16 Aug 2003 04:45 pm |
