DST CMR Custom tunes
Like Tree3Likes
  #11 (permalink)
Old 12 Oct 2017, 03:54 am
SPLNeon's Avatar
Default Re: DST CMR Custom tunes
Originally Posted by zztunnell View Post
It's an 03 autostick. Its not a Stage1 pcm. But it is a new pcm. It has a sticker on the side that says upgraded software. Haven't had time to pull it and get the numbers off of it yet to be sure what it is.
Ok, if it was a stg1 pcm you would have had the 04+ injectors and the diablotune for the 03 is calibrated for the smaller injectors , that's why I was asking.
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.72at 116mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
  #12 (permalink)
Old 12 Oct 2017, 09:04 am
I did install the 577cc injectors. It had rhe pink ones in it. I figured with the upgrades I'm going with I'd need them. I planned from the outset to get the DST and a custom tune. Didn't realize a tuner was that hard to find. It runs pretty good now even though it's rich at WOT. Ought to scream once I get a tune.
  #13 (permalink)
Old 12 Oct 2017, 12:09 pm
SPLNeon's Avatar
Yes the diablotune for the 03 is calibrated for the pink/purple injectors , that is why you are seeing a rich condition when WOT
Handy_Cruiser likes this.
96 SOHC Neon Turbo
  #14 (permalink)
Old 26 Oct 2017, 04:45 pm
chris15's Avatar
A bit late to this party, but Nigel at BST is one of the best tuners you'll find.
Brutal Speed and Tuning
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
  #15 (permalink)
Old 29 Oct 2017, 10:44 am
My 03 gt auto does the same thing around 4000 rpm. It started after I returned from Germany and had the timing belt replaced. My master tech think a they installed one tooth off. I have tried everything on the predator to try and correct it.
2003 pt/gt deep cranberry metallic
blow-off valve, 2-1/2\" jeg\'s duals, k&n, 215/50r17 coopers, 10\" lightening audio sub, kenwood 5-channel amp, pioneer speakers...stage 1 soon
  #16 (permalink)
Old 30 Oct 2017, 05:08 pm
Does what at 4000rpm exactly?
  #17 (permalink)
Old 31 Oct 2017, 07:33 am
Starts knocking because act goes to 10:1 and stays there. I have tried more boost more timing end even cut fuel by 20% on the tuner and it still does it...at higher boost levels and rpm it feels like Breckenridge is kicking in
Drain tunes Ali7805 PT Cruiser Convertible Forum 1 21 Sep 2017 03:33 pm
Custom Diablosport tunes 149.99 sykedtuner Vendors & Buyers Forum 22 01 Jan 2015 12:41 am
No tunes tazszzzzzz General PT Cruiser Discussions 0 21 Aug 2013 04:35 pm
