Walbro 450lph modifying canister Help!
Like Tree4Likes
Old 31 Mar 2018, 07:54 pm
Default Walbro 450lph modifying canister Help!
I'm planning to take my PT to heights that have never been reached before, over 600 horsepower, and I need the fuel system to take it there. I have with me a Walbro 450 lph pump, deutchworks 750cc injectors, and a PT GT canister and I need some help figuring out where I should route all the hoses. wiring seems straightforward, just connect the right wires. Before anyone says anything about power handling I am going to have DCR axles for the T850 which has the same spline count and diameter as the getrag, and I am also getting a stage 3 South Bend clutch. I don't really care about traction, its fun to roast tires anyway.
Old 31 Mar 2018, 11:14 pm
Default Re: Walbro 450lph modifying canister Help!
I ended up cutting a lot of the excess plastic that holds the stock fuel pump to make the walbro 450 fit. It in in the canister, and still uses the factory wiring and hoses. I did swap the hose going from the pump to the body to a braided steel covered hose. If I ever want to go back to the factory pump I can fairly easily. I tested it using a 12 volt drill battery and it ended up working fine, so I think I found the easiest way to install a large fuel pump in the stock canister with hardly any modification. Now I just need feedback. Do you guys think it will work fine?
Old 01 Apr 2018, 07:46 am
SPLNeon's Avatar
It may work fine.
What I would have done is keep the stock fuel pump and use an external 450 and a surge tank up front.
The budget for a 600+ hp set up should include a fuel system to support it
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.72at 116mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 01 Apr 2018, 10:49 am
Realistically speaking anyone attempting to build a PT Cruiser with more then 300HP should have a stand alone Fuel system.
SPLNeon likes this.
Old 01 Apr 2018, 11:10 pm
I will spend the money for sure, but i have no idea how to create an external fuel pump, and I bought a 450 from a friend. I want to use it in my system. Any pics of an external fuel setup?
Old 01 Apr 2018, 11:14 pm
I was thinking that the 450 alone should be enough for the power I知 planning on going for. I知 also not quite sure what size injectors would be a good pair with the pump. I currently have 750cc injectors. Mainly what I知 asking is how much fuel would I need to support what I知 going for and how can I achieve it?
Old 02 Apr 2018, 11:42 am
rob302's Avatar
https://fuelinjectorclinic.com/flow-calculator
808PTcruiser likes this.
Old 02 Apr 2018, 07:22 pm
_PTGT03's Avatar
The problem is not roasting the wheels. It's getting them not to hop. I already have new mounts with the hard urethane inserts and there is still wheel hop. The wheel hop is going to shatter the axles if done enough. I think you have a great ambition, but it would be wise at your age to put this money from the project into going to a mechanical engineering program. That would pay off long term, then with your increased income and knowledge you could really do a proper job.
Old 09 Apr 2018, 10:17 pm
I have solid motor mounts and bc coilovers so I hardly get any wheel hop, and I just need a better clutch and some dcr axles and I値l be fine. Besides I知 not taking it to the strip every day I just want a really powerful daily. I知 not really looking for 600 hp I知 more looking into a doable 450-500 range.
Old 09 Apr 2018, 10:19 pm
I kinda realize now that 600 hp is gonna be real expensive, and I知 sure I値l be happy with 500 to the wheels.
255 walbro question mattsptgt Tech & Performance Forum 1 22 Aug 2011 03:30 pm
255 walbro mattsptgt General Turbo Discussions 0 21 Aug 2011 11:14 pm
Need Help Modifying Cargo Area- Bolting down mods peters_anvil The Detail Shop 2 11 Aug 2010 09:27 pm
walbro 255 lph PTcruzer02 General Turbo Discussions 0 16 Sep 2009 10:25 pm
Modifying stock springs azheat Turbo Wheels/Suspension/Handling 10 29 Nov 2003 10:58 pm
