PT Cruiser Forum Car Videos
Custom Wheels
Hyper Grounding
  #11 (permalink)
Old 09 Aug 2004, 12:35 pm
Dalite Dalite is offline
quote:Originally posted by JPMS GT
Did anyone try this or get more information or do I smell snake oil?[:I]
Jn[8D]
RE Grounding on digital systems
When an electronic system uses digital logic, it relies on Boolean Algebra to "branch" electronic flow based on the laws of Logic. The short answer is that the path to ground is switched rapidly to control electron flow within the circuit.
When there are various paths to ground, a "Ground Loop" or "Feedback Loop" situation is created. In this situation, a signal seeking a path to ground may travel hundreds of miles within a second of time seeking a path to ground to dissipate.
For this reason, it is crucial for all digital circuits within a subsystem (Car) reference the same ground. Different ground paths create a "difference in ground potential" in which the signal's ground is reached at different times. In the case of the Cruiser, with all the different controllers that are networked to the PCM, precise grounding is crucial; anything added into that networked system (read accessoires: fuel management, engine control, audio, etc.) must reference the same ground used by the network. You will find an entire witring "Bay" at the PCM dedicated to ground for this very reason.
Toasters and hair dryers don't rely on critical ground paths. Digital systems depend on a Precise Ground Path (note the non-plural spelling; as in one path to ground).
To get mpore perspective, talk to someone who does computer networking; specifically UNIX networking via Serial links. If they are worth their salt, they can elaborate (at length) on the need for precise grounding where digital sugnal paths are concerned.
The very short answer: Enhanced Grounding (properly done) can only improve performance, reliability and consistency.
Given that reply, also consider that there is nothing available to the general public that cannot be improperly used, improperly installed, or manufactured from cheaper components to cater to a market share that considers price only as criteria for purchase.
If you do decide to enhance the grounding system, do it properly with quality components using high quality connections and terminating hardware. (This is where the snake oil determination process comes in).
  #12 (permalink)
Old 09 Aug 2004, 05:16 pm
JPMS GT JPMS GT is offline
Thanks for the input Dalite. Once I get used the the Stage I performance I might just stop buy SunAutomobile, around the corner from me, and see what they have. The improvement potential sounds logical.
Jn
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
  #13 (permalink)
Old 09 Aug 2004, 05:27 pm
ajoeb ajoeb is offline
Jn[8D]
  #14 (permalink)
Old 09 Aug 2004, 05:32 pm
DALITE, Good brain candy. Thank you.
  #15 (permalink)
Old 11 Aug 2004, 11:17 pm
Boosted Wagon Boosted Wagon is offline
I believe turbo magazine just had a 4 or 5 page review on the different types of grounding systems. One company said that its an easy 12 horses in 5 minutes. My cousin has the jacobs on his 1.8t jetta and it was a noticable differnce in throttle responce engine smoothness.
03 GT Patriot
H&R coilovers,CAI,Mopar/Borla exhaust,Mopar stage 1,VAK UCP, Maxxfab 3\" DP,blitz spec r ebc,PSI-FI solid motormounts,AFX udp,turbochargers wga ,18\" g racing seiki w/ blue spokes wrapped in 235/40/18 bfgoodridge Gforce kdw\'s, PTeazer roll pan,hot rod front bumper with custom molded piaa fog lamps,Pioneer 7300 dvd player,1 10\" kicker L7 sub,
  #16 (permalink)
Old 19 Aug 2004, 09:19 am
macster macster is offline
Send a message via AIM to macster
My set should be here today 8/19/2004. If I get them before 4m on Friday I will test them at the track. Also I will do a Dyno on 9/10/2004. This should be fun. I was told by a guy that was running the whole system that the Hyperground helps from the mid to upper end. Anyway, the concept works because I made a set for myself just to test the concept and I was satisfied with the initial results.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #17 (permalink)
Old 19 Aug 2004, 01:49 pm
nozzano22 nozzano22 is offline
JPMS, how about seeing if SunAuto will offer you a 'group' package? If the price is right I will send you a check for a set, maybe others will also,
Mike
  #18 (permalink)
Old 19 Aug 2004, 05:15 pm
When I first talked to them they were reluctant to sell out of the office and refered me to a store. I'll see what I can do. Maybe someone like TThrift could get a jobber price and resell them to us. I would just as soon buy from a PT type than just any store.
  #19 (permalink)
Old 20 Aug 2004, 04:24 am
Mean Green Mean Green is offline
I'd buy from Tommy any time.....Also would be interested in a group buy if the price was right.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #20 (permalink)
Old 20 Aug 2004, 11:14 am
GR8FLPT GR8FLPT is offline
keep us posted on this!
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
vB code is On
Anyone ever install a "grounding" kit before? Wicked_PT General PT Cruiser Discussions 6 05 Dec 2005 08:25 pm
Sun System Grounding Wires SteelBlueGT General Turbo Discussions 13 24 Jul 2005 11:16 pm
N/A Hyper ground KingKole02 Tech & Performance Forum 12 20 Jul 2005 08:23 am
got my Energy Suspension Hyper flex kit Ctown Wheels, Tires, Suspension 10 31 Dec 2004 02:00 pm
Grounding sites for gauges PTGT Redman Tech & Performance Forum 7 25 Jan 2004 04:55 pm
  Loans | Remortgages | Foro de informatica | Digimon Episodes | Free Ajax Scripts
