Turbo bolt torque question....
  • 1 Post By MrTzPT
Old 18 Apr 2019, 06:18 pm
Default Turbo bolt torque question....
Hey everyone! In the middle of head gasket/timing belt replacement on a 2007 turbo & the book is pretty vague on the oil return bolt torque. If I am reading it correctly, the torque on the two bolts for the oil return on the bottom of the turbo is 30ft lbs. Is this correct?? Seems kind of high for those two little bolts...
Thanks in advance!!! MrT
Old 19 Apr 2019, 12:13 am
Default Re: Turbo bolt torque question....
My manual is for an 05 so this might not apply to your 07 but it calls for 105 inch pounds on the oil return bolts.
2005 Limited, Auto and Turbo Lite
Bone stock
Old 21 Apr 2019, 10:31 am
Thanks! That sounds a LOT more believable than 30 ft lbs. Better to go low & see if it leaks than to break them off!! I can always tighten them a little more....
Cat22 likes this.
Old 21 Apr 2019, 08:00 pm
With a good gasket. It shouldn't leak. I pretty sure those bolts won't take 30ft pounds. Most all torque specks are inch pounds on these. Module year will not make any difference for torque specs.
Old 23 Apr 2019, 07:43 pm
Exactly my thinking!!! I wasn't about to torque them to 30ft lbs...book or no book!!! Looks like the book is wrong on this one. 30in lbs is nowhere near enough, so not a misprint on that part.
Transmission Pan Bolt Torque paulwells77 General PT Cruiser Discussions 5 04 Jun 2017 01:38 pm
Head and Cam Bolt Torque specs? Kittysnax Tech & Performance Forum 1 06 Nov 2012 02:35 am
Caliper Mounting Bolt Torque ? Dorkygrin General PT Cruiser Discussions 2 17 Jun 2010 06:15 pm
bolt torque specs?? GTCruiser2003 General Turbo Discussions 1 30 Mar 2004 04:33 pm
third bolt on BOV.....help....torque also ptcruzin42 Stage Turbo Kits 7 26 Aug 2003 10:05 pm
