Turbo Oil Leak
Like Tree2Likes
  • 2 Post By RCSnyder
Old 30 Jan 2020, 08:07 pm
Default Turbo Oil Leak
Now that I have 2 turbocharged 2005 PTs in my driveway, I need to look a little closer at the source of oil leaks on the backside of the engine.
On the Ltd car, I have replaced the sending unit and valve cover gasket. I've not yet touched - but have poked around - the recently acquired GT.
It seems, however, the oil leak might be the same source on both cars, and may be related to the turbo oil return line. The rubber portion of the oil return on both cars seems dubious.
Am I headed in the right direction?
Bob in Liberty
Old 31 Mar 2020, 07:44 am
Default Re: Turbo Oil Leak
I think I got 'em.
While the rubber return hoses are soft, they weren't really contributors to the problem.
The GT had a leaky oil pressure sending unit. I'd replace that a few years ago and it was, once again, pushing oil through the unit.
The Ltd seems to have been a poor seal under the front camshaft saddle. I had done the valve cover gasket when I bought the car last year, but went no farther at that time because the original seal was very tired. This time I pulled that saddle and it was metal-to-metal. Whoever did the head work for the previous owner may have spready the goop too thin, or not at all.
Bob in Liberty MO
podo2000 and chuzz like this.
Turbo leak tester Pippov General Turbo Discussions 1 09 Apr 2016 07:47 am
Water Leak on Turbo chuzz General Turbo Discussions 10 18 Sep 2015 01:46 pm
pt turbo vacuum leak cruiserbruiser05 Tech & Performance Forum 12 24 Mar 2014 10:07 pm
Water leak Under turbo 03turbo Tech & Performance Forum 14 11 Feb 2013 09:24 pm
05 turbo...large oil leak Alonsoli Tech & Performance Forum 3 02 Nov 2012 01:41 pm
