Nice work Strange.
This work was done over a year ago with an 5 channel data recorder sampeling temps all over the engine compartment. Graphs and pix are posted on my website. Great to see someone else making the effort to fan the flames!! check it out at; http://www.bstockum.com Enjoy! ... Bob Stockum Highly DeveloPT Cruiser |
Hey Bob,
I found your site absolutely amazing. Seems you have done your reaserch and ten some. I was wondering since you did these tests last Aug. if you had an early version of the stock PT Turbo and stock intercooler, or if you were running a Hahn turbo etc? Also have you done any permanent modifications to the hood to allow for heat venting, inducting? My main concern is filtering out debry and water. I was thinking of constructing a large filter, and maybe fabricating a carbon fiber water trap to channel water away from the engine. Maybe I need to look closer at your site, but there is a lot of info there for right now. I hope that your are not mad about me adding part of you website here, but I thought it would be helpful for others interested in this subject. By the way Bob Rocks<img src=icon_smile_question.gif border=0 align=middle> the following comes from Bob's site http://www.bstockum.com/toohot.html Quote:
Here is the temp graph Bob ran with weather strip on. For details go to Bob's site http://www.bstockum.com/toohot.html ![]() Here is another temp graph Bob ran with the weather strip removed. Comparing the two graphs you can see that without the strip the engine bay stayed 20 to 25 degrees cooler. I have seen the same results since I have been measuring temp while commuting to work during the day. <img src="http://www.bstockum.com/town_nostrip.jpg" border= |
sorry here is the second graph without the weather strip.
Cool fresh air flowing in from windshield base isn't bad. Cool water (rain, car wash, etc.) hitting a hot exhaust manifold is very bad. Check the cost of a new manifold/turbo before leaving the weatherstrip out.
...I've been a car enthusiast for years and an engineer by trade. I now own and operate a custom car speed shop. I learned years ago about venting through the rear of the hood. I have done this modification on virtually all makes and models of cars and usually it's the first thing I do. Hot air is actually sucked out from the engine compartment by the venturi created by the air flowing over the windshield. It is harmless with the only drawback being that it also allows hot air to be drawn into the passenger compartment by the hvac system, the base of the windshield is also where the air intake is for the hvac. What we have done is to just leave a short ,18 inches, piece of the weather-strip on the passenger side. It stops the vent air from feeling like an oven and smelling like a hot engine in the car. Very little water enters through the opening because the turned up lip stops it and with the PT it is several inches toward the front...An added bit of info...finish off the sharp edge that's left exposed with a piece of door edge guard, either black or chrome and it will look good and won't cut you up while cleaning the car. We also have experimented with various opening sizes...the result is anything over about 1/4" is no gain. The amount of air coming out is in direct relation to the speed of the car...so open the sunroof and run up to about 100 mph and just stick about 1/2 of your finger out and see just how much air is being pulled out...We also have found that with small displacement engines they never get to operating temperature in extremely cold weather, they actually become 'air cooled'. With the PT we get multiple positive affects from this no cost modification...it is one of the few cars that actually have a complete seal all around the hood..so the venting out the back is quite efficient...just some info for your evaluation assistance. If you want to look further into it, it also stops the positive pressure from building up under the hood and the increased flow through the radiator is tremendous...Hate to keep rattling on but we also have noticed that in the summer fewer bugs will hit your windshield with the flow of air out and over the glass!
Inferno red GT/R-package/heated seats/rear wing/5-speed |
WOW.. Lots of good info earringboy. You to Dr. GT Strangelove. A snow storm messed up my traction control mpg test. Will snow again tomorrow here.
Looking in my airbox I couldn't see where taking the white piece out of the top would help other than removing the plastic ring around it. In the bottom the black plastic tube goes 1/2 way through the box. Couldn't get it apart without breaking it. Got the ole Dremil tool out. Cut a half circle out of the top of the plastic where the air comes out. The air should be going more directly through the box now (less twisting and turning). Could take a pic of it but have no site to post it on. Will think about cutting the rubber at the back of the hood. Leave it on where the heat&air vent is. Gets real hot here in Oklahoma in the summer. |
Hello,
I have been running Mobil Supersyn 5W-30 for the past week and I have seen a 5 degree drop in engine running temperature. With the added benifit of not needing to let the engine run for a few minutes to let the turbo cool, to prevent coking this is a plus. The average temperature I am seeing during highway driving is 15 degrees f above the outside temp. Still working on the ram air scoops for the undercarriage. |
Sorry guys, I think I erred. Visited the the friendly local DC dealer today to look more closely under a GT hood. The exhaust manifold/turbo is probably safe. That large heat shield over it should sizzle any rain that makes it that far in short of a frog-strangler.
I plan on using Mobil 1 5W-30 too. The forums here have lots of good oil info. http://www.bobistheoilguy.com/
Think I will remove the rear hood gasket on the drivers side only. The heat & air vent covers about half the width. Don't care to suck in engine heat during the summer. The engine air intake is on the drivers side anyway. |
One of the most fascinating threads I've had the pleasure of reading. I am not an engine guy, but I have a question about removing the weatherstrip: it looks like the concern orignially posted about damage to the manifold has been put to rest, but what about drag created by removing the weatherstrip? If we imagine the sucking motion of the wind swooping over the hood will now suck air from under the hood when it didn't before, doesn't that sound like it would slow the car down with all that added friction?
If you haven't cruised Maryland, you haven't cruised. (unless you cruised somewhere else) |
| Cost to Drive a PT Cruiser | Puck | General PT Cruiser Discussions | 7 | 29 Mar 2004 10:59 am |
