PT Cruiser Forum Car Videos
Custom Wheels
Champion Blowout
Old 18 Aug 2004, 01:56 am
Kirby Kirby is offline
Default Champion Blowout
Changed my plugs for new Champions at 35K, along with some new Magnacores. The unusual finding wasn't that the plugs were only slightly worn, the suprise was that ALL FOUR PLUGS HAD BLOWN THEIR CERAMIC/METAL SEAL.
The heat lines went from the metal jacket up the ceramic stem of the plug. One still had some sealing material loosely in the crevice between the jacket and stem.
Would an Iridium NGK be better sealed? This had to be robbing power from each compression stroke.
Another not so nice supprise was that the Jiffylube folks that charge me $65 for a Mobil One oilchange knocked the crancase ventilation hose off (open to mother natures worst).[8)]
Old 18 Aug 2004, 09:50 am
Mike Radowski Mike Radowski is offline
65 bux for a Mobil one oil change??? They provided the oil, right? My Chrysler dealer does it for $18.00 if I provide the oil and the oil is like $20.00 at SAMS club. Let's see, 20 + 18 does not = $65.00. Hmmmmm, must be missing something.
Mike
Old 18 Aug 2004, 01:18 pm
Mike-in-Orange Mike-in-Orange is offline
I had Jiffy Lube do my first change with Mobil 1 and got the same $65 bill - that was enough for me. I'm doing the rest at home now, using K&N oil filters and Mobil 1 from Wal-Mart. Another thing I noticed when I changed oil last week was that Jiffy Lube had used the oil filter for the N/A PT, not the turbo. Bastards! Only difference is that the turbo filter is a bit longer, otherwise the fit is the same. I say again - Bastards!
Old 18 Aug 2004, 07:06 pm
macster macster is offline
Send a message via AIM to macster
Kirby
Are you coming out to Fontana Sat? If so I have a set of NGK's that you can test out.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 19 Aug 2004, 01:53 am
Would like to be there this weekend, I'll try.
Thanks[8)]
Old 19 Aug 2004, 07:59 am
Spend your next $65 on Rhino ramps ($20) an oil catch pan (maybe $10), Mobil 1 5-quart jug at WalMart (about $20), Filter (say, $5), and spend the remaining $5 on beer after you've changed it yourself..
Old 19 Aug 2004, 01:01 pm
I have stands and equipment, but I use my PT for business and cannot afford a time consuming battle over warranty if something happens. At 70K I will change at home as I do with my 4 other cars.[8)]
vB code is On
Screamin' Demon Coil, LiveWires & Champion HighFive Tech & Performance Forum 2 27 Mar 2007 08:57 am
Audio Blowout DBROWN03 Classifieds: For Sale/Trade 0 16 Aug 2006 11:53 am
Champion Iridium Plugs rszappa1 Tech & Performance Forum 5 06 Feb 2006 08:09 am
Champion Irridium plugs - DON'T!!! quicksilverdon Tech & Performance Forum 12 19 Jan 2006 10:48 am
MSD Coil, Hotwires, Champion Platinum LAF Turbo Performance 1 28 Feb 2004 05:39 am
  Loans | Web Advertising | Buy PSP | Loans | eHarmony Promotional Code
