Just yesterday I started having this problem (or i think its a problem at least). When I step on the gas (conservatively) my RPMs will rise faster than the car is accelerating. I have a 5 speed BTW. For example, in 5th gear cruising at 60 my RPMs are at about 2500. If I go to accelerate to 70 my RPMs will rise quickly to about 6000 and then sort of settle in. It is a lttle hard to explain, but it is kind of similar to the transmission slipping in an automatic but there is no jerking. I am not flooring it either, this is just normal acceleration. My car has around 27000 miles on it. Any insight would be greatly appreciated.
Any chance you've been a bit hard on the clutch and it's slipping? My old BMW had a similar problem and it was indeed a worn clutch, but with 150,000 miles on it.
Yup, clutch is going. I wouldn't let it slip too much or you could burn up your flywheel too. It should be machined when you do the clutch assembly but if you wear it too much you will have to buy a new one.
Even if you do not see a substantial amount of wear, if the surface is not flat and finished properly, you will either smoke the disc prematurely +/or experience chatter. This would be a good time to research the possibility of a High Performance standard clutch housing/disc and flywheel. Does anyone know if there is aftermarket clutch/flywheel available? Just my 2 cents ![]() higear please keep us posted, is it actually the clutch? |
Sure sounds like a clutch to me, too. Have driven manual trannies all my life and you are describing a slipping clutch. Could be a failed pressure plate or a worn clutch disk or both. But with only 6000 miles, could also be an oil leak causing the slippage. Either way, the clutch assembly will have to be replaced, an oil soaked clutch disk is useless.
Mike |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Flying high | AlmondTurbo | General Turbo Discussions | 2 | 22 Aug 2004 08:10 pm |
| High RPM Miss potential Fix | Exhaust Depot | Turbo Performance | 11 | 15 May 2003 06:31 pm |
