I would like thoughts on a dual stage boost controller like this one: http://www.agpturbo.com/customer/pro...&cat=24&page=1
I like the fact that you can control boost for in town and on the highway. Pros and cons? Thanks |
Tom,
Your still going to need the new billet AGP waste gate (should be available within the next few days)to go with the boost controller. In fact the biggest HP increase will come from the WGA. You'll need to keep your high boost setting under 17.5 lbs. boost to keep the cpu from pulling timing unless you install a map-clamp. Those two pieces (WGA and 2-stage boost controller) should get you close to Stage 2 ratings. The downside is you'll start experiancing PTB or Part Throttle Boosting. At 50% throttle of above you'll go to full boost conditions. Offering two stages of boost somewhat puts a bandage on the PTB problem. That's why Stage 2 would be so nice if Mopar ever get's off it's duff and releases it. S2 would give us more HP with the same driveability that we have with Stage 1. Deen
GT, 5-Spd, K&N filter, Stage I, AGP 3147 Big Turbo, DTEC Fuel Kit, Tial WGA, Greddy Profec EBC, DCR 55mm TB, 05 Plastic Manifold, 180 Deg. Stat, CCA FMIC, AMX hard-pipes, Water-Injection, STS shifter, Needswings 3\" DP w/dump and Borla Cat-back, BG Drop Springs, Eibach Sway Bars, Panther alloys & Eagle F1 Max-Performance Tires. Best run to date...12.93 @113.45MPH. 77 Blown Vette-runs 10\'s @ 136 MPH. |
Thanks Deen
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Just a thought ![]() |
Just make sure you by the HP version.
It will help hold boost till redline. George
If you see a edit,Its probably cause I didn\'t spell something right. What can I say,school was fun. Well maybe. |
You can get the HP version in a Single or Dual stage boost controler. It has a extra adjustment(brass hex stock with adjusting screw)on top of the single stage(low boost)bleed. The(high boost)2nd.stage bleed doesn't have this extra adjustment. What it does it allows you to adjust your boost HOLD in a sense. It can be adjusted so whatever boost you have your wastegate and boost controler set to.It will allow you to hold that boost longer/ or to a higher RPM before it falls of at redline. There are actualy 3 adjustments on the HP model.Low,High and hold/spike. I think they call it spike in the instructions. I did have spike and bleed off with mine until I adjusted it out. And now on the PT and on the SRT when I had it they both will hold boost till about 300 rpm before redline then fall off to about 2lbs. less than what I was holding. To me thats pretty good because I seen my car at first and others drop off to 15lbs. by redline.I'm holding 20lbs to almost red line the falling off to 18lbs about 300 rpm before redline.That way your makeing good power all the way to redline. It (hp dual stg. boost controler) will also get rid of the part throttle flutter that you get when you start running a higher boost level. Maybe thats why they call it that.HP that it is a higher performance version of thier standard boost controler. I don't know for sure why the call it HP.Just guessing on that part. George
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| Final manual boost controller installation | Ian-PT-GT | Turbo Performance | 83 | 10 Jul 2003 11:57 pm |
| MMi Dual stage boost controller | OVcruzn | Turbo Performance | 1 | 30 Jun 2003 03:03 am |
| Dual Stage Boost Controller Installed!! | RobGT | Turbo Performance | 13 | 21 May 2003 12:35 am |
| ? gauges for dual stage boost controller | tthrift | Turbo Performance | 3 | 01 May 2003 10:32 pm |
