k. sry bout that.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
SakiGT, where did you get the Mopar BOV? I have looked at the mopar shops on this web site and some local dealerships and no luck. Did it come powder coated blue or...
Let us know where you happened across the goods.[8] Nice looking PT- are you a big Girl-Racer? You have that whole stealthy-dark overlord thing going on. Good job and good luck dropping into the 13's! That will be impressive, especially with a stock exhaust!
.R3dWhitNCrz http://mysite.verizon.net/vzepobb2/ |
![]() Now with stage 1 ![]() Just a GT... Thats tearin\' arse on the driveway. http://www.cardomain.com/id/themanfrmokinawa 14.626 @ 94.74 stage 0 , intake and exhaust only. |
![]() 14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!! |
stock BOV dumps boost back into turbo when you back off the power (ie. to shift gears) and can cause the turbo to slow down a bit.
The Mopar "add on" BOV dumps the extra boost to atmosephere and maintains turbo speed better. More huff and puff....... ![]() |
We really have beat this topic into the ground on previous posts but there is no power increase with the bov and stock it actually can keep the turbo spinning and cool it. Noise maker only, even the DC engineers said this.
Just my 2c ![]() |
How good does it sound? I was looking at an RFL from HKS ... but since they dont make anything for the PT and it would have to be all custom, I decided to go with the Mopar one ... Im just hopeing that it sounds good!
The OEM BOV is called a Surge Valve Actuator or SVA. It does not blow off to the atmosphere, so BOV is a misnomer The vacuum solenoid that operates it is called the "Surge Solenoid." It is the middle one, numbered 3 mounted on the right shock tower. The valve reduces boost when vacuum is applied to it by opening a passage between the output and the input of the charge air turbine. If the vacuum line is opened, there wil be maximum boost. I thought mine was stuck so I disassembled it. Not stuck. The easiest way to remove the right bolt is to point your 10mm combination wrench straight down. Helps if it has a ratchet drive built into the box end.
| Need Help with pics Crewzin???? | turbomangt | Non-PT Discussions | 11 | 03 Aug 2006 11:10 am |
| my newest mods. NEW DAYLIGHT PICS | CruiserDan | Exterior Accessories Forum | 10 | 27 Oct 2005 08:00 pm |
| pinstriping pics requested! | mikehrz | Exterior Accessories Forum | 3 | 26 May 2005 10:44 am |
| Cruisin' the Blue Ridge Parkway pics | FloweryBranchCruiser | General PT Cruiser Discussions | 7 | 28 Sep 2004 12:25 am |
| More Pic's | stirfry | Sound and Security Forum | 7 | 18 Apr 2004 11:30 pm |
