PT Cruiser Forum Car Videos
Custom Wheels
OEM BOV anyone have pic's or drawings?
  #11 (permalink)
Old 12 Oct 2004, 03:45 am
PTGT Redman PTGT Redman is offline
k. sry bout that.
Homepage:
  #12 (permalink)
Old 15 Oct 2004, 12:54 am
R3dWhitNCrz R3dWhitNCrz is offline
Send a message via AIM to R3dWhitNCrz
SakiGT, where did you get the Mopar BOV? I have looked at the mopar shops on this web site and some local dealerships and no luck. Did it come powder coated blue or...
Let us know where you happened across the goods.[8] Nice looking PT- are you a big Girl-Racer? You have that whole stealthy-dark overlord thing going on. Good job and good luck dropping into the 13's! That will be impressive, especially with a stock exhaust!
R3dWhitNCrz
http://mysite.verizon.net/vzepobb2/
  #13 (permalink)
Old 15 Oct 2004, 02:04 am
Mr.Blonde Mr.Blonde is offline
Send a message via AIM to Mr.Blonde
quote:Originally posted by R3dWhitNCrz
...where did you get the Mopar BOV?...Did it come powder coated blue ...
You can get it from TThrift. they come in the blue, they wont work on N/A engines.
Now with stage 1
Just a GT... Thats tearin\' arse on the driveway.
http://www.cardomain.com/id/themanfrmokinawa
14.626 @ 94.74
stage 0 , intake and exhaust only.
  #14 (permalink)
Old 15 Oct 2004, 05:44 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
Ebay, it comes blue, and If I get into the 13s WITH an exhaust Ill be surprised. Not sure if I want to do drag radials now or not. Worried about the driveability of this thing outta college. Last Chrysler I buy until they fix these tranny issues.
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
  #15 (permalink)
Old 23 Oct 2004, 01:50 pm
2step 2step is offline
stock BOV dumps boost back into turbo when you back off the power (ie. to shift gears) and can cause the turbo to slow down a bit.
The Mopar "add on" BOV dumps the extra boost to atmosephere and maintains turbo speed better. More huff and puff.......
  #16 (permalink)
Old 23 Oct 2004, 07:26 pm
ptgtcb ptgtcb is offline
We really have beat this topic into the ground on previous posts but there is no power increase with the bov and stock it actually can keep the turbo spinning and cool it. Noise maker only, even the DC engineers said this.
Just my 2c
  #17 (permalink)
Old 18 Nov 2004, 08:32 am
Fast04PTGT Fast04PTGT is offline
Send a message via AIM to Fast04PTGT
How good does it sound? I was looking at an RFL from HKS ... but since they dont make anything for the PT and it would have to be all custom, I decided to go with the Mopar one ... Im just hopeing that it sounds good!
  #18 (permalink)
Old 04 Aug 2008, 12:28 pm
icezebra icezebra is offline
Default OEM BOV (SVA) Pics here
The OEM BOV is called a Surge Valve Actuator or SVA. It does not blow off to the atmosphere, so BOV is a misnomer The vacuum solenoid that operates it is called the "Surge Solenoid." It is the middle one, numbered 3 mounted on the right shock tower. The valve reduces boost when vacuum is applied to it by opening a passage between the output and the input of the charge air turbine. If the vacuum line is opened, there wil be maximum boost. I thought mine was stuck so I disassembled it. Not stuck. The easiest way to remove the right bolt is to point your 10mm combination wrench straight down. Helps if it has a ratchet drive built into the box end.
vB code is On
Need Help with pics Crewzin???? turbomangt Non-PT Discussions 11 03 Aug 2006 11:10 am
my newest mods. NEW DAYLIGHT PICS CruiserDan Exterior Accessories Forum 10 27 Oct 2005 08:00 pm
pinstriping pics requested! mikehrz Exterior Accessories Forum 3 26 May 2005 10:44 am
Cruisin' the Blue Ridge Parkway pics FloweryBranchCruiser General PT Cruiser Discussions 7 28 Sep 2004 12:25 am
More Pic's stirfry Sound and Security Forum 7 18 Apr 2004 11:30 pm
  Compare | Credit Cards | Debt | Wills | Payday Loan
