the part number I gave was for the srt-4, will fit on the GT, same engine. I went with those because they are 1 heat range colder. You should be fine with what you ordered.
R_K_GT \'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come..... |
I am sorry, I intended to state the price and the gap, but forgot.The plugs as received were .052 and I gapped them to .045. I found .045 was a good all around range.Use a wire plug gap tool and the electrode adjust tool to bend the ground electrode, don't tap on a hard surface as many people do. As long as you don't force the wire between the electrode and ground you won't have any trouble.I found that the folks on the SRT forums have it together, and seem to have more support from Dodge than we do from Chrysler.They also seem to have access to more performance parts. You PT owners may want to check out the forums.
Thanks for the info [?]
BTW, I think most of us here do keep and eye on the SRT board occasionally[^]
See Kevin's 2003 Elec Blue GT here: http://www.cardomain.com/ride/477590/1 |
I'm curious SRT folks would go with LZTR6AIX-13, when SparkPlugs.com & NGK both recommend LZTR5AIX-13 for both the SRT Turbo and PT Turbo.
Plus, where did you get the info on the heat range. I can't find that at NGK's website.
![]() <b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i> |
Thanks. I also contacted NGK tech support. They recommend the LZTR6AIX-13 on heavily modded cars (upgraded turbo, boost controller, etc.). Since all I have is a GT with S1, Borla exhaust, & Airade CAI, the LZTR5AIX-13 should be suffecient. Plus it being a daily driver, with a couple of rare street races, I find no need for the LZTR6AIX-13. Maybe if I go with Stage 2 will I look into the LZTR6AIX-13.
FYI, the tech also stated NOT to change the gaps on the NGK Iridium plugs. EDIT: Hmmm. After further research. NGK's website states that it's better to run a colder plug. Too cold of plug can lead to fouled plug. Too hot of a plug can lead to engine damage. I guess, if I get the LZTR6AX-13, then I'll save myself some money instead of buying the LZTR5AX-13 now, then the LZTR6AX-13 when Stage 2 comes out. Time to change my order. Hopefully, it can be changed immediately, since my LZTR5AX-13 is supposed to arrive on the 20th.
| E3 Spark Plugs | CREWZIN | Tech & Performance Forum | 6 | 11 Dec 2004 01:03 pm |
| Spark plugs: newbie question | Edwin Astacio | Tech & Performance Forum | 12 | 01 Nov 2004 12:21 pm |
| spark plugs | ote69 | Turbo Performance | 24 | 12 Oct 2004 01:44 pm |
| ZEX Spark Plugs | Jerry | Tech & Performance Forum | 9 | 27 May 2004 07:32 pm |
| Ignition Questions....need help. spark plugs | ptcruzin42 | Tech & Performance Forum | 5 | 15 Mar 2004 08:39 pm |
