PT Cruiser Forum Car Videos
Car Rims
AGP Wastegate actuator
  #11 (permalink)
Old 20 Nov 2004, 05:51 pm
ptgtcb ptgtcb is offline
I went to the agp web site and could not find install instuctions and they do not even list the PT GT WGA, could you post the instructions?
Are you running it with the stock set up or between the tan and brown lines bypassing the #2 solenoid, if so how does the pressure bleed off. Are you using a MBC or EBC between it?
It seems we would still have a problem with the surge/bov opening up?
[:I]
  #12 (permalink)
Old 20 Nov 2004, 06:11 pm
dfunkdj dfunkdj is offline
Send a message via AIM to dfunkdj
Hey did you have to remove the intake to get the heatsheild off??? I was bust today working on other projects and installing my pillar pod with gauges.. How hard were the heat sheild bold to loosen also ??? Hope to maybe have time sunday to install. Are you running your WGa straight or with a MBC ????
Don
<font color=\"orange\"><b>2003 Dream Cruiser II
Stage 1, Greddy blow off valve, AGP WGA, Custom open dual exhaust, Denso plugs, Xtremeboost upcharge pipe, AMX intake pipe, Ramair hoods hood, Apc ground effects kit, lowerd 3\", Turbo xs MBC, auto meter double gauge pod, and 2 more gauge mountd on sterring wheel {oil psi and temp, boost, water temp}
apc 2nd gen tail lights, more to come soon
Tampabay Pt Cruisers</b></font id=\"orange\">
  #13 (permalink)
Old 20 Nov 2004, 10:16 pm
tthrift tthrift is offline
Send a message via AIM to tthrift
[:I]
hey ptgtcb, i am the only one with the agp wga right now even agp isn't selling them yet . if it wuld help you i can email you a set of instructions just email me your email address and i will send on moday.
tthrift@haynesjeep.com
thanks tommy
  #14 (permalink)
Old 20 Nov 2004, 11:17 pm
amazingarthur amazingarthur is offline
Does the wastegate make that big of a performance difference?
2004 GT Cruiser Electric Blue, Stage 1, Ghost Flames, Boyd Coddington Smoothies.
Borla Duals, unecessary Airad CAI Thing, 18\" Boyd\'s Smoothies, and she\'s dropped an inch or two.
www.amazingarthur.com
http://www.cardomain.com/memberpage/559523/1
  #15 (permalink)
Old 20 Nov 2004, 11:35 pm
Mean Green Mean Green is offline
I heard it is 20 more hp after 4000 rpm. Tommy?
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #16 (permalink)
Old 21 Nov 2004, 12:52 am
i know it makes a lot more HP but i don't know any soild HP #'s
thanks tommy
  #17 (permalink)
Old 21 Nov 2004, 03:22 pm
So where do I get one and how do I put it on? Details, please.
  #18 (permalink)
Old 21 Nov 2004, 06:20 pm
hey arthur call me and i will take care of you.
tommy
1-800-296-5337 ext 338
  #19 (permalink)
Old 29 Nov 2004, 09:46 am
Hey Tommy,
WOW !!!!! It like a new stage-1 and then some. My Pt really takes off now you can jump from 40mph to about 80mph in a couple of sec's. If you got stage-1 and liked it this will be as much if not more fun..
Cant wait to get to the track and see what it will do I think Lakeland {1/4 mile} and maybe Sunshine {1/8 mile} Are still open.
Don
Don
  #20 (permalink)
Old 30 Nov 2004, 01:57 am
hyracer hyracer is offline
Don
Don, read my posts under "I Don't Need Stage 2 Anymore" for a detailed install. The heat shield bolts are on tight and will require a 6-point 3/8th socket to break them loose. I broke a 1/4" drive socket on mine. The bolts are made of a copper/bronze material and you could end up stripping the head if the socket slips.
If I had to do it all over again I would have removed the intake manifold for easy access. The bolt heads on the heat-shield are 10mm. Once you have them broke loose you can use a 10mm combo-wrench for those with tight clearances.
Good luck on your install,
Deen
vB code is On
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
AGP Wastegate strangelove Turbo Performance 8 21 Oct 2006 08:01 am
TThrift--billet wastegate actuator CJJ Turbo Performance 8 15 Sep 2004 07:47 am
Wastegate Info Needed GTPT Turbo Performance 10 05 Dec 2003 12:16 am
Wastegate Actuator And No Need for Boost Controlle FRM3 General Turbo Discussions 11 01 Dec 2003 10:51 pm
  Bad Credit Mortgages | Credit Cards | Personal Loans | Loans | Mortgages
