PT Cruiser Forum Car Videos
Custom Wheels
Final manual boost controller installation
  #51 (permalink)
Old 09 Apr 2003, 02:06 pm
flashbk2 flashbk2 is offline
Just got back from dealers...had no boost controller and stock air box back in. They said they checked for loose connectors -ntf(no trouble found). They told me not to clear code if it happens again and bring car right in. I backed off the boost a bit more and re-installed my "outlaw" setup. Will keep you all posted . It sure was "sad" the way the car ran without the "outlaw" setup ! Boost is addictive ! .<img src=icon_smile_evil.gif border=0 align=middle>
'03 Electric Blue 5 speed GT, bassani axle back single exhaust,addco oversize front,rear sways,wildfire strut bar,color-matched rear muds,xenon sides,mirrors,b&c pillars,both interior consoles,b&m sport shifter
  #52 (permalink)
Old 09 Apr 2003, 02:39 pm
Ian-PT-GT Ian-PT-GT is offline
So, it is safe to say that there is definitely a difference in engine reaction and vehicle performance???
I have ended up with a setup for normal cruising of 9-PSI in the low range and the engine still going to 14-psi at Wide Open throttle at fourth with the factory solenoid control.
At the track I am using a 12-14 PSI setup.
I have noticed that you have to lower the setting for normal driving or the fuel rail dries up and the engine starts to knock. This can only be corrected with an increase of fuel pressure. As of today, I have not found a way to increase fuel pressure.
I am inclined on getting the Greddy profec b controller that lets you dial two different pressure settings and switch from one to the other with the flick of a switch.
Exhaust depot,
Can you get this controller at a good price for us?
I know you have the E01 controller but the Profec b is three wires, two vacuum lines and adjust.
Ian
  #53 (permalink)
Old 09 Apr 2003, 03:10 pm
Most definately there is a drastic performance difference. I just re-installed my "outlaw setup" . Presently I'm running about 12-13 on initial pop and drops to about 10 and holds. I'm going to drop it still further to be "safe" but it is definately much better than stock ! I also wrapped my intake in insulation to isolate from engine heat it ain't pretty but I'll bet it helps !
  #54 (permalink)
Old 10 Apr 2003, 05:43 pm
Chipmunk Chipmunk is offline
Just got back from testing out the Hallman Boost Controller I put on today, OH MY GOD!!! Talk about a difference! The turbo spools so much faster now, its incredible.
With the controller on now, when you step on the gas a little and lets say the psi goes to 8, it stays there instead of dipping back down. Very cool.
The first setting I tried peaked @ 14psi and goes down to about 10 or 11psi. Which is exactly where I want it. I drove pretty hard and didnt see anything over 14, so I beleive im on the safe side.
A big thanks goes out to Ian and Flashbk2 for all their great input on this subject.
Now I just gotta clean out my engine compartment from all the salt and crap from winter :-(
Matt
2003 GT Cruiser
Edited by - Chipmunk on 04/10/2003 16:43:56
Edited by - Chipmunk on 04/10/2003 16:45:21
  #55 (permalink)
Old 10 Apr 2003, 05:53 pm
I'm glad you like it Matt . Are you gonna be @CFIII maybe we can hook up and chat ! I got same problem here with salt ect.! Got mine washed /waxed today ! I think Ian hits the dragstrip ,tonight I'm sure he'll post something !
  #56 (permalink)
Old 10 Apr 2003, 05:57 pm
Hey Flash, Do you have AIM or Yahoo IM, be great to chat more often.
My AIM is Chpmnk1200
My YahooIM is Chipmunk1200
Matt
2003 GT Cruiser
  #57 (permalink)
Old 10 Apr 2003, 06:26 pm
Have AIM but lost password and customer service hasn't emailed me back. I work from 20:00-04:30 am don't know how aften we'd get to chat ! When I get back from Florida ,I'll get my id staightened out ! We're leaving the 16th and returning the 27 th.
  #58 (permalink)
Old 11 Apr 2003, 05:49 am
Well,
Went to the track yesterday but got a rain check....
Yep, It rained.... <img src=icon_smile_sad.gif border=0 align=middle>
Couldn’t do anything. I had a great testing list for yesterday but nothing.
Had brought the car to factory setup with all the silencers and no boost controller for the first pass. Was going to install the controller and test, later remove the silencers and test again, finally increase boost again and retest. Yesterday was all the passes you can do for $7.00.
O well, will do it next week.
Ian
  #59 (permalink)
Old 11 Apr 2003, 08:48 am
Will Will is offline
Well I finally got the greedy profec b hooked up and it is much better than before but it still drops back down to 10 to 11 pounds in 1st and 2nd gears. In third it stays at 14 and havn't got to 4th yet to tell what it does. I hooked it up to the line at the back of the turbo and the boost reg line on the actuator. I then tried it by hooking it up to the rear turbo output line and the rear of the turbo but it still drops. It is better and when you turn the controller off it is like stock. I'm running low at 11 and high at 14. I don't have the remote switch yet but plan to get it so I can leave the line at 8 or so in low and then hit high to go to 14 so it gets better traction. No codes with eithwer hook up but if anyone has tried something that will keep the boost up to 14 with no drop let me know. The difference is well worth the cost of the greedy b. It's like a different car now. <img src=icon_smile_8ball.gif border=0 align=middle>
  #60 (permalink)
Old 11 Apr 2003, 01:56 pm
Well I got another p1188 again last nite . I got when cruising and not into boost @ all. Took it to the dealer ,today supposedly ordering a sensor. On the plus side I let my wife drive the car with/without the boost contrller . She says she wished some of my higher dollar mods showed as much as difference as this $50.00 one ! .
vB code is On
New Old Topic - Manual Boost Controller jramosGT Turbo Performance 10 31 Oct 2007 06:46 am
$5 BUCK BOOST CONTROLLER! MARKS-GT Turbo Performance 24 06 Oct 2006 04:46 pm
Turbo XS Boost Controller With Adaptor blueberrygt Classifieds: For Sale/Trade 2 08 May 2004 06:08 pm
Boost Controller Versus PCM FRM3 General Turbo Discussions 3 08 Oct 2003 10:59 pm
Boost Controller and Gauge Questions Dalite Turbo Performance 13 14 Jul 2003 01:20 pm
  Credit Cards | Watch Naruto Online | Just Holden Commodores | Online advertising | Bargain Flights
