PT Cruiser Forum Car Videos
Custom Wheels
Final manual boost controller installation
  #71 (permalink)
Old 12 Apr 2003, 09:17 am
flashbk2 flashbk2 is offline
Matt here's a pic where I'm tapped into vacuum for my boost gage . The big hose near the top goes to rear of intake.
'03 Electric Blue 5 speed GT, bassani axle back single exhaust,addco oversize front,rear sways,wildfire strut bar,color-matched rear muds,xenon sides,mirrors,b&c pillars,both interior consoles,b&m sport shifter
  #72 (permalink)
Old 12 Apr 2003, 10:58 am
This mfrom pte guru MX5 who has the manuals I'll be getting in May Throw away that Haynes manual and get the OEM service manual set.
Page 343 of the 2003 powertrain diagnostic manual:
P0234 - Overboost performance
P0243 Wastgate solenoid circuit
P1188 Throttle inlet pressure sensor performance
There are 7 pages of diagnostic information on those codes.
  #73 (permalink)
Old 12 Apr 2003, 11:40 am
Ian-PT-GT Ian-PT-GT is offline
Chipmunk,
Just a thought,
Install the BOV on the rubber tube going from the Intercooler to the Mass Air Flow Sensor just before the throttle body. It will be inside the engine compartment and not under the car where a bump can break it.
I don't now if this hose that I am talking about is the best place to put it but it is just another option.
Ian
  #74 (permalink)
Old 12 Apr 2003, 05:17 pm
Chipmunk Chipmunk is offline
quote:
Chipmunk,
Just a thought,
Ian
Thats a good thought Ian, Im not quite sure if it will fit there though. But that hose would be much easier to take off I think. Do you know if those plastic rings that couple peices together around the tubing come off some how? I also need to find out how much a replacement hose will cost.
Matt
2003 GT Cruiser
  #75 (permalink)
Old 07 May 2003, 06:31 pm
jramosGT jramosGT is offline
I haven't installed my controller yet as I just did the boost gauge. I have the silencers out and the K&N filter in place. I'm only seeing 10 psi max boost. I'm getting good vacuum, but certainly not the boost. I'm hooked up per the pic at http://www.vinylguy.com/boostgauge.htm.
I'm trying to borrow another boost gauge (or I'll pull the one in my RX-7) to confirm whether the boost gauge is defective or I'm not making boost.
Jumpin\' Joe
\'04 Porsche 911 GT3
\'01 Audi S8
\'05 Chevy 2500HD TurboDiesel
\'05 Suzuki SV650
  #76 (permalink)
Old 07 May 2003, 11:44 pm
Gary C Gary C is offline
Send a message via AIM to Gary C
have you thought about upgrading the wastegate actuator? (in referance to the boost tapering off. The SRT's were doing the same thing, as the actuator unit stock can't hold the boost through redline, and it seems like a weak link in this application when the boost creeps up to the 14lb mark. It's been having trouble holding the peak boost in the SRT's and I'd imagine as it's the same setup in the GT that we're having the SAME trouble those guys are.
they got 280 some horse and 290 some lb feet at the wheels with a mix of 100 octane in the tank and 91 with boost at 17psi with just a MBC and acuator! *www.turboxs.com - check out the SRT stuff, I've found it VERY informative in getting ideas and applying the ideas to tweaking the PT cruiser turbo so far.
http://www.srtforums.com/phpBB2/viewtopic.php?t=2906
http://www.agpturbo.com/
http://www.turboxs.com
thats the thread i'm refering to.
I will be installing their setup as soon as the dual stage boost controller and gauges go in, EGT *VERY important*, Boost, and AF down by the cup holders, and the rest in the glove box. (i want as stealth an install as possible, as I'll also be hiding the air ride controls in the glove box and the dual stage nitrous switch under the dash.
2003 GT cruiser
209HP 248lb/ft SAE corrected
  #77 (permalink)
Old 11 May 2003, 10:27 pm
Bump for old head and others to read about setup's
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
  #78 (permalink)
Old 24 May 2003, 09:36 am
hyracer hyracer is offline
Ian,
Where did you mount your boost gauge and Auto Meter pod? Also what are the part numbers so I know what to order?
Thanks, Deen
  #79 (permalink)
Old 26 May 2003, 04:48 pm
I could never find the single gauge pilar pod so I got an old school autometer mounting bracket and got a black wire protector to cover the wires and the vaccum line. I don't have the part numbers but I know that it was the cheapest one, $12.00 for the black bracket and $50.00 for the gauge.
Ian
  #80 (permalink)
Old 26 May 2003, 05:46 pm
gsharrock gsharrock is offline
Gary C -
I've been over on the SRTForum and found the same info. Some of the guys are using the AGP Waste Gate Acutator WITHOUT any boost controller to get 14 psi, rock steady, no spikes and no p1188 errors.
I ordered the Waste Gate Actuator and BOV block-off plate last week and will be installing them this week, along with the BOV from Hector at Exhaust Depot. If I can adjust the Waste Gate Actuator to get the boost I want with a controller, and with a CEL error, I'm there! I'll post again with an update.
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC — The WooX 30w x 2 powered subwoofer
vB code is On
New Old Topic - Manual Boost Controller jramosGT Turbo Performance 10 31 Oct 2007 06:46 am
$5 BUCK BOOST CONTROLLER! MARKS-GT Turbo Performance 24 06 Oct 2006 04:46 pm
Turbo XS Boost Controller With Adaptor blueberrygt Classifieds: For Sale/Trade 2 08 May 2004 06:08 pm
Boost Controller Versus PCM FRM3 General Turbo Discussions 3 08 Oct 2003 10:59 pm
Boost Controller and Gauge Questions Dalite Turbo Performance 13 14 Jul 2003 01:20 pm
  Dream Interpretation | Per Insurance | Libro infantiles | Loans | Share Prices
