Data Logger now available
  #21 (permalink)
Old 19 Jan 2005, 10:36 pm
Boy, coming from a N/A performance background, it pulled a bunch of timing out! Check line 10.
10 0:00:46 55speed 3,097RPM 60.00%throttle 21.50timing
Only 21 degrees at 3000 RPM? I realize you need to pull out timing when boosting, but that seems like a lot. Okay, did a quick search and found this. http://www.turbo-kits.com/b18ci_gsr_vtec_dyno.html
It says "Timing Retard: There were no significant differences in power between 0 and .5 degrees of retard per pound of boost. There was also no significant difference found between .5 and 1.5 degrees of retard. But the difference was obvious between 0 and 1-1.5 degrees of retard."
If you were boosting to about 10 PSI, that would mean somewhere around 31 degrees (1 to 1), so I guess this looks okay, given the head is a fast burn design (less need for timing). Would be interesting to see load/timing/throttle #s....
I bet there are SRT guys that could quote chapter and verse on this stuff.....
second pole for data tthrift Vendors & Buyers Forum 22 14 Sep 2004 02:10 pm
Event Data Recorder? zzzhuh General PT Cruiser Discussions 18 13 Sep 2004 03:21 pm
pole i need data for ( big brother ) tthrift Stage Turbo Kits 27 30 Aug 2004 08:03 pm
Stage I & Stage II OBD Kirby Stage Turbo Kits 3 18 Nov 2003 11:00 pm
Bad News for GT & Data Logging Programs Dalite Turbo Performance 9 31 May 2003 12:20 pm
